Help d16z6 issues
Old Mar 11, 2010 | 10:29 AM
landonsdad's Avatar
TRIAL USER
Default Help d16z6 issues
Ok so i have a 91 CRX with a d16z6 in it the car runs and drive fine but i didn't do the swap I was given the car the harness is all hacked up, some of the senser tips are missing and and the map senser isn't even connected. my question is if I replace the harness should I go with the stock crx harness, if so how do i find out what motor was in it to begin with the d15b2 or the d15b6 or do i just get the d16z6 harness and the convertion jumper and p28 ecu? one way or another I should buy a new harness I just need to know which one would be the best
Old Mar 12, 2010 | 07:46 AM
dephtone's Avatar
Default Re: Help d16z6 issues
Get the stock CRX motor harness. What submodel is the CRX? Dx, HF, Si? Whichever it is, that is the harness you will want to get.
8th POSITION GRADE in the VIN tag:
5 = (Std)CRX (DPFI)
6 = HFCRX (MPFI)
6 = Si CRX (MPFI)
Old Mar 12, 2010 | 07:52 AM
lunalink's Avatar
get a stock si/hf harness and a ecu jumper
Old Mar 12, 2010 | 08:12 AM
jlicrx's Avatar
Si anf HF engine harnesses are not the same
Old Mar 12, 2010 | 08:13 AM
lunalink's Avatar
i meant it as in get either an SI harness or an HF harness
CRXosaurus
Apr 1, 2013 04:36 AM
jdmsuckah
Sep 2, 2010 01:35 PM
SuperTuner12010
Jan 21, 2008 05:59 PM
whiteguyndahood
Jun 23, 2006 04:39 PM
RicedREX
Aug 8, 2004 03:52 PM
