DC2 leaking transmission
Old Mar 11, 2010 | 06:23 AM
touge's Avatar
Default DC2 leaking transmission
The transmission on my ITR is leaking from this big plug that I circled in this picture. Anyone know what this is for? Any ideas on what I can do to stop the leak? It's not a really bad leak but I would prefer to fix it so I don't need to worry about checking my fluid and making a mess on my garage floor.
Old Mar 11, 2010 | 06:40 AM
get RIGHT's Avatar
Default Re: DC2 leaking transmission
Looks like the C-clip bolt, 1/2” socket bolt. You can tighten it with 1/2” socket.
I used this thread for refrence.
https://honda-tech.com/forums/transmission-drivetrain-127/b-series-transmission-teardown-rebuild-tutorial-2443459/
Old Mar 11, 2010 | 10:12 AM
8OOSTED's Avatar
Its a C clip plug for the secondary shaft. You can try to back it out a little and put some rtv sealant on it then tighten it back up.
Old Mar 11, 2010 | 10:40 AM
touge's Avatar
Thanks for the help
But is it safe to remove this plug, put some sealant on the thread and put it back in without messing up my transmission? I understand I will lose some oil but thats no big deal I can just top it back up.
Old Mar 11, 2010 | 12:28 PM
chasered07's Avatar
rtv is fine it wont go pass the threads unless you dunk the whole thing in rtv.just lightly out it on the threads of the plug
Old Mar 11, 2010 | 12:53 PM
tipe R's Avatar
you could also use liquid thread sealer which will probably work better then rtv. it's basically liquid teflon tape. if it can seal propane fittings, then it can seal an oil leak
Old Mar 11, 2010 | 01:08 PM
touge's Avatar
But is it safe for me to remove the bolt without some shaft in the transmission falling out of place or something?
I just want to make sure I don't mess something up just trying to fix a small leak
Old Mar 11, 2010 | 02:07 PM
chasered07's Avatar
its just a plug.nothing should come loose to my knowledge
Old Mar 11, 2010 | 02:36 PM
Rus1an's Avatar
No shaft in the trans will fall out when you remove it. just make sure you dont tighten it too hard and crack your trans housing...
Old Mar 30, 2010 | 10:18 PM
jdmturboitr's Avatar
Ever resolve this leak? I'm having same issue now....
Old Apr 22, 2010 | 04:18 PM
nuttzy's Avatar
Bump, how did ye fix this?
Old Apr 26, 2010 | 10:47 AM
touge's Avatar
I only just tried to fix this leak today because it was getting worse.
I took the plug out and tried to using some of that tape that is made to seal fixings but I didn't like how it went on, don't think it made a great seal. But anyway I took the car for a run and parked it up and left it for a few hours and it still leaked but only a very small amount, much better than it was before. So I might try taking it out again and using some silicone gasket maker I have which I think will work better.
If any of you guys are going to try this be careful with the plug the threads don't look like they can take much abuse and mines were partially stripped when I took the plug out The transmission had been rebuilt before with the previous owner so I guess someone had overtightened it or something.
Old May 24, 2010 | 03:19 AM
touge's Avatar
Incase any of you guys with similar problems are wondering how to fix this I managed to stop the leak with some Threebond 1215 Silicone Liquid Gasket I had laying around.
I just backed the plug out a little bit, cleaned it up with petrol and covered the threads in the silicone gasket maker and tightened it back up and let it cure for 2 days. The Threebond is good stuff, it's made for sealing 2 metal surfaces together and stopping oil getting through.
Does not leak at all now
Old May 24, 2010 | 06:03 AM
get RIGHT's Avatar
Good news.
I noticed my tranny was leaking too. Turns out the reverse plug/sensor had backed itself out. Tightened that and problem solved.
E-PiLLs
Mar 28, 2013 10:39 PM
JMoneyJigga
May 28, 2004 10:07 AM
WhitEdRift
Feb 13, 2004 10:44 PM
ShiftDown
Jul 30, 2002 11:44 PM
