EF Hub on EG?
Old Mar 10, 2010 | 10:07 PM
kristianhay's Avatar
Default EF Hub on EG?
Does anyone know if a Momo hub from an EF will fit on my EG? Thanks.
Old Mar 11, 2010 | 08:45 AM
Default Re: EF Hub on EG?
tttt
Old Mar 11, 2010 | 11:49 AM
.Manny.'s Avatar
Touching My Member
I don't think so, I believe the "EF" one has a slightly smaller spline.
Old Mar 11, 2010 | 12:44 PM
Hm, anyone else? I've heard it does and I've heard it doesn't, lol.
Old Mar 11, 2010 | 01:09 PM
likwid2u's Avatar
ive done eg to ef and the only advice i can give is check the bolt every now and then cause it might loosen
Old Mar 11, 2010 | 01:44 PM
I'm doing EF to EG, not the other way around haha.
Old Mar 11, 2010 | 02:54 PM
.Manny.'s Avatar
Touching My Member
I really doubt it will, trade or sell the one you have and get the correct one. Don't gamble on the steering
Old Mar 11, 2010 | 03:20 PM
scottmog's Avatar
no it wont
Old Mar 11, 2010 | 06:48 PM
ef9ridda's Avatar
i think it will but there are some modifying to do...
in my personal opinion as far as my steering wheel being able to turn when i want it to i wouldnt mess with it unless its a REAL aftermarket setup for MY car... just saying....
Old Mar 11, 2010 | 07:07 PM
hushypushy's Avatar
It will "fit"; the splines are exactly the same. I was rocking a NRG hub for EG on my EF for a while.
HOWEVER, if you're putting an EF hub on an EG, the splines are not the issue, it's the "lip". I have a Momo EF hub, and I tried putting it on my EG. It went on the splines perfectly, but the big lip wouldn't clear the steering column plastic. I don't have my NRG hub anymore to show the difference, but EG hubs are flatter.
In other words, if you want to use the Momo EF hub on an EG, you have to take off the steering column cover.
hispanic panic
Jan 7, 2019 06:12 PM
kristianhay
Mar 11, 2010 12:10 PM
Wazup
11
Dec 5, 2009 05:35 PM
r3D2_Fan
Apr 29, 2008 01:52 PM
Hanmin
Jan 15, 2008 10:32 PM
