rear wiper?
hahahaha all those guys are idiots if they can't figure out how to get the motor out of the glass.
The shaft is press fit into place, meaning you'll have to use leverage to push it back out. I just wrapped needle nose pliers in a towel and pressed it through.
Not being a dick, just trying to a help fellow out here. The wiper arm itself is pressed *straight on*. There is no rotation involved in its removal. Rotating it will only break it, and possibly your rear window. Don't rotate the wiper arm, just pull straight out on it. Use a set of 2 or 3 arm pullers easily available at your local Autozone. Or, if your doing a rear wiper delete like I did, just cut through one side of the wiper arm. :-p
See Attachment:
Red box is where you take off the nut that holds the wiper arm on. Its a regular thread.
Blue box is where the wiper arm presses on. Vertically threaded, No turning.
jcorange
Oct 2, 2017 09:55 AM
archie77
Nov 23, 2013 12:21 AM
timrichter9
Jun 23, 2011 12:06 PM
