JDM ctr crank pulley...what belt to used???
like title says...i put the pulley on my gsr and the stock gsr alt. belt is too long....so i was wonderin what belt i should used? sohc's?
If you can't find the P# by searching... you can do the string trick.
If your belt already has the correct width/# of ribs. Use a piece of string around the pulleys and cut it to where the ends just meet, then measure it to get the correct length. Take the belt back to the parts store, and give them the length you need & they can grab one that should work for you.
Andrew
Andrew
ya know, if you would do some of your own work, search around, maybe call someone that sells ctr pulleys, ask what belt they use you could get results alot faster.
Andrew
Andrew
Also IIRC, the ITR uses the same alternator belt as the CTR.
gsrsuperman
Dec 2, 2007 07:57 PM
