Trailing Arm Bushing
im trying to buy some Trailing Arm Bushing for my eg..but idk which to get oem or energy suspention bushing...my car is droped on 1piece tein..so idk which would better what do u guys think
The energy suspension takes way more work to install. I used them because they were cheap $22 on amazon for a pair while an oem-style was $32 each and a Honda one was forty-something or so.
For the ES you have to re-use the old steel outer ring and center shaft and the best way to get all the old rubber off is to burn it off in a campfire. Then you have to reassemble which and get everything lined up (take very good measurements before you take it apart). Overall it's way more of a pain in the *** to do the ES but it was cheaper. I could care less about supposed "performance" benefits of the ES. That and the OEM ones would probably just fail again and the ES look like they'll last forever. Although either will last the average owner for as long as they plan on owning the car but for me I've owned my 96 since it was new and plan on keeping it rolling for a long time to come.
I think there are some mixed opinions about the TA bushings.
Some say poly bushings such as ES or prothane are too stiff and cause binding and OEM or mugen ones are way to go, but I had ES bushings on few of my cars without any problems. They worked fine and lasted as long as I owned the car.
prothane are good ones.
i buy all of my bushings and stuff for suspension from energysuspensionparts.com
they are really good dudes. great customer service.
I wouldl advise against polyurethane trailing arm bushings because they don't "bounce back" like OEM/Mugen/HardRace rubber bushings. When the poly deforms, it stays that way.
Your other options are spherical bearings. I have one from Blox, and I recomment it over rubber. The whole car feels more precise when driving compared to rubber. I wouldn't buy Blox again, because of their usual dodgy quality control standards on a lot of their products, so I'd be looking at upgrading to a PCI or Hardrace spherical bearing rear trailing arm bushing if you're going to go that route.
philosofy1
12
Oct 29, 2007 01:08 PM
