99 ACCORD AUTO TRANS
Hello, this is common problem. There is a selector ring on a fork kinda of like a striaght drive inside the trans that selects forward motion or reverse. The teeth are worn off and thats what you hear grinding and it won't spline in. The trans will have to be pull out and tore apart to fix it,probably be best to rebuild it while that is being done because they have problems with the clutches anyway. Hope this helps.
It's probably best to get one from the junkyard. Go to www.car-part.com to look at local junkyards. I wish you luck.
Lokie37
Jan 3, 2004 03:51 PM
