INDY-PART OUT-the left overs,wilwood,integra,civic,buddy club,b18c,type r,MUST GO
IVE GOT SOME PARTS LEFT OVER FOR A DC2 2DOOR INTEGRA SOME WILL FIT CIVICS AS WELL. (PICS APON REQUEST)
1)WILWOOD BIG BRAKE KIT 140-6163D---$500 NEW (*SOLD*)
2)BUDDY CLUB SPEC2 EXHAUST BCO3-SP2EXDC2---$300 NEW (*SOLD*)
3)JE PISTONS(pn:242874) 82MM 11.5-1 COMP+PROBE INDUSTRIES RODS(pn:14100)---$450 NEW** (YES BOTH )
**B18C1 BLOCK --- b18c1 arp headstuds,main arp studs,moroso 5.5qt oil pan+gasket,oem honda 15100-p72-a01 oil pump,bore 82mm+hone+resurfacing,non oe water pump,micropolished gsr crank --- $700 (will also part out pm me an offer for the parts you want)
--Itemized:
>arp head studs(pn:208-4303):$115
>arp main studs (pn:208-5403):$70
>moroso kicked out 5.5qt steel oil pan+gasket(pn:20910):$200
>oem gsr oil pump(pn:15100-p72-a01):$100
>non oe gsr water pump:$50
>micropolished oe gsr crank:$150--(* sold *)
>machined 82mm bore bare block:$300
--Itemized total:$985
($800 if purchased as a whole)
**B18C1 HEAD --- FERREA single valve springs(s10028)+aluminum mag retainers(e10018), SUPERTECH flatfaced black nitrade valves(hivn100f/hevn100f), 3 angle valve job, temp coated, &resurfaced. --- $900 (will also part out pm an offer for the parts you want)
Itemized:
>ferrea valve springs (s10028):$275
>ferrea aluminum magnesium retainers (e10018):$125
>supertech black nitrade flat faced in/ex valves(hivn100f/hevn100f):$200
>p72 head resurfaced,3 angle,temp coated,stock cams,vtec sol.,valve cover,(without above components):$300
**NONE OF THE ITEMS HAVE BEEN USED ALL NEW**
--Itemized:
Itemized:
i still have all these left buy them now or forever be smitten like a kitten
oh yea if you were wondering what the pistons look one is my profile pic.
heres an app list for the brake kit op
ACURA INTEGRA1994-2001
HONDA ACCORD1995-1996
HONDA CIVIC1994-2000
HONDA CR-V2001-2001
HONDA ODYSSEY1999-2001
HONDA PASSPORT1994-2001
HONDA CR-V2001-2001
is the head and block all put together. just need head gasket and manifold and blah blah and ready to go??? lmk im interested.
block: pistons sold separately assembly required but does come with gsr crank
head: is pretty much put together valve springs & valves are installed basically ready to be installed not much assembly required.
