Rattle Can Job, AGAIN.
Old Mar 10, 2010 | 12:43 PM
4g4dcruisin's Avatar
Default Rattle Can Job, AGAIN.
Has anyone wet sanded a rattle can job? Below is the color im doing my eg, Krylon Gloss Hasta Leaf. I've always enjoyed Krylon as it has the vertical/horizontal tip, and the coverage is excellent and for the most part, even.
My roof and hood are black, i'll probably paint the trunk black just to match, so i wont need much cans of green. When i laid down a test area, i got some shine, more than i thought, then screwed it up by putting Rusto-crap clear coat over it, which fogged it up actually.
So, is it possible to wetsand away the orange peel left by a rattle can job? I went to an automotive paint supply shop and got some killer sand paper, 600, 800, 1000grits. This **** is better than the 3M Automotive Paper from kragen or wherever. I sanded the area with 600grit and got a great smooth surface so i decided to just paint over that. I got a little orange peel but not too bad.
You cant see it in the pic, cuz it was taken with my phone, but here is an idea of the color. I've done this 4 times prior to this EG, but i wanted to try wet sanding the base coat this time.
Old Mar 10, 2010 | 02:28 PM
Default Re: Rattle Can Job, AGAIN.
bump
Old Mar 10, 2010 | 02:55 PM
graham412's Avatar
you should just paint your entire car over with a gun instead of a rattle can. even though its more expensive its definetly worth it. ive never once seen a good looking paint job done with a rattle can and it definetly wont last as long either. im not trying to be a dick but it would be well worth your time and money
Old Mar 10, 2010 | 03:21 PM
Well, here is one that looks good, that i did, and that is very durable. I know what im doing with a spray can, im simply asking if spray paint, with multiple coats, would be able to withstand wetsanding.
Old Mar 10, 2010 | 05:17 PM
datsol94's Avatar
car looks good man i did the hood trunk n targa on my sol using the roll-on rustoleum method. im not 100% on spray paint but i wetsanded between each coat with progressively finer grits 800, 1000, 1500, 2000. i'd imagine that as long as its prepped correctly, you keep it wet, and dont sand too much down then you should be good. as long as you take your time and dont rush it i dont see why it wouldnt work.
Old Mar 11, 2010 | 12:23 AM
hellajdm333's Avatar
i to now how to use a can! but ive always said id never spray can a honda! but thats just me! but if you take your time i think you could pull it off! the more paint/ more coats the better! good luck man
Old Mar 11, 2010 | 02:55 AM
77777's Avatar
why dont you people just paint your cars the right way...or just ride a bike around?
Old Mar 11, 2010 | 04:23 AM
apexi_rsx's Avatar
i seen on clubRSX a guy doing a rattle can job with clear coat. it came out glossin looked good i never thought it was possible to look good untill i seen the post. wetsanding is the key issue here and waxing it after a month wouldnt be a bad idea.
Old Mar 11, 2010 | 04:32 AM
h-o-n-d-a's Avatar
yea looked okay in a picture probably. i bet it didnt looke that great when you see it in person. link please for this spray can cleared rsx? seriously i get the whole okay i cant afford a paint job so im gonna spray paint my car and what not. but now clearing a whole entire car with a F'n spray can? come on thats ridiculous. id rather have a maacco job for $250 then to do all of that time and effort to make spray can clear look semi decent.
Old Mar 11, 2010 | 07:04 AM
Because i get bored with the color of my cars, anyone on this forum that knows me will tell you that. I paint with spray cans because,
a. im good at it.
b. i dont want a professional paint job that i may get tired of 6 months later.
3. i have two kids, gf, morgage, and bills to spend my money on.
Im reconsidering my color choice, i dont think i want to attempt getting a glossy shine with spray, it will come out blurry most likely, i think im gonna stick with flat or satin...probably burgundy.
it IS possibly to achieve a good paint job without paying someone to do it professionally. You've never seen it in person, and never will since i've sold it.
Like i said before, i have better things to spend my money on instead of paint i WILL be tired of 6 months down the road.
Old Mar 11, 2010 | 07:38 AM
RCurioso88's Avatar
You know what, if you think you're good at it and you think it looks good on your car, then more power to you, man. Don't let anyone stop you. Plus the civic you painted didnt look half bad either so go for it. As for wet-sanding it, i'm not too sure lol
Old Mar 11, 2010 | 07:47 AM
Thanks man, im not second guessing myself, it just bugs me when people knock on stuff they havent tried for themselves.
Old Mar 11, 2010 | 09:56 AM
blkcivic310's Avatar
I CANT DENY YOU DO GOOD WORK WIT A RATTLE CAN
Old Mar 11, 2010 | 09:59 AM
D3vin's Avatar
I rattle can'd my slipstreams back then and wet sanded the primer up to 2000grit then to the actual paint. I can tell you, it was a really beautiful job because it was one of the nicest job I have ever done. BUT, **** start fading.... Due to the heat maybe? Anyways, if you going for rattle can I would get matte colors like flat black, white cuz I used the Duralast Graphite color with the gloss. Hhhmm, maybe I used the wrong kind of too.
Old Mar 11, 2010 | 10:13 AM
96romaEK's Avatar
Rattle can paint jobs, when done correctly, can look pretty good and last for a while. I did this one last summer: (the shadows on the door are from the neighbors tree)
Old Mar 11, 2010 | 10:26 AM
^^that looks good, im scared to do anything dark like that. There is a tendancy for spray paint to become blotchy and its more noticable in darker colors. The color im doing my car seems to be holding up pretty good so far, i kind of half assed the prep because i mainly wanted to see the color, and it looks fairly decent. I finally found my digital camera so i should be taking some better quality pics this weekend with the new paint!
Im debating, should i color match my lip/sideskirts/mirrors? i have no side moldings being a CX so im curious about this....here is my old EG with color matched everything.
Old Mar 11, 2010 | 12:04 PM
D3vin's Avatar
Hhhmmm, actually you can try rolling the paint. =D Then wet sanding.
Old Mar 11, 2010 | 12:21 PM
eh, yea, i've done that...im not a fan of Enamel paint like that. When i got my EF painted, it had Rusto Protective Enamel...i was told that i had to get that **** off COMPLETELY, or else the new primer wouldnt stick.
Old Mar 11, 2010 | 12:53 PM
iamthefollower's Avatar
I like the flat colors from the spray cans, hope you choose a good color .
Old Mar 11, 2010 | 12:56 PM
I think the green, in my pics on the first page, will end up alright. I'll cover everything in a bunch of light coats, i know how to avoid orange peel when i really want to.
Old Mar 11, 2010 | 04:18 PM
hj2's Avatar
hj2
hey OP, check out this thread:
http://forums.clubrsx.com/showthread...ght=rattle+can
i think one of the other guys was referring to this.
this guys definitely makes it look good, GL
Old Mar 15, 2010 | 07:18 AM
PICS! Finished with this on saturday, let me know what you think.
Old Mar 15, 2010 | 07:19 AM
Holy ****, i didnt know there was THAT much glare in the first pic...i'll take more crappy phone pics later.
Old Mar 15, 2010 | 07:30 AM
Kuhniee's Avatar
looks good from what i see! and all the people giving you **** dont know the potential apparently ha
Old Mar 15, 2010 | 07:33 AM
Thanks, im at work right now so i'll go take more pics here shortly.
