Brake Questions
I have a set of EM1 Rotors and Pads from my last car, and now have a 95 EX coupe
1. Will the front Rotors and Pads fit the 95 EX ??
2. What is the size difference between the 95 EX and EM1 Calibers and rotors ?
3. Will the rear Rotors and Pads fit a LS or GSR rear brake swap, or should i try to find a swap from a EM1?
4. What is the size difference between the EM1, LS, GSR rear brakes, calibers and rotors?
The rotors and pads will not work. To make them work you will need the spindle, caliper, caliper mount, pads, and rotors. I'm not sure the exact size difference between the two but it is noticeably different. As for the back i'm not sure it will work or not. I'll let someone with a rear disk swap to chyme in for the answer.
k thanks, also what about the Brake Lines? how do they differ from a 95 ex to 99 si ?
i know they will work cuz the fittings are the same, but will have to make a bracket to hold them?
variable
Jun 22, 2009 06:07 PM
