d16z6 running rich after cam gear install
Old Mar 9, 2010 | 06:51 PM
smmcla's Avatar
Default d16z6 running rich after cam gear install
I have a d16z6 in a 90 crx si. I installed a skunk2 cam gear and put the timing to tdc. The timing belt is a little loose. The problem is that the car runs and idles fine for the first 15 mins. then after that it will have a rough idle and have a small faint gas smell. no smoke out of the exhaust. through out the rpm range it runs great. every-once in a while the o2 sensor will come on. (im guessing bc it is running to rich). When I turn off the car and open the gas tank cap a lot of pressure will wizz out. Sometimes it won't want to start until i let the pressure out. I had that problem before the engine(the not starting). any ideas?? im fresh out. thanks
Old Mar 10, 2010 | 12:30 PM
smmcla's Avatar
Default Re: d16z6 running rich after cam gear install
anybody?
vtrp2008
10
Aug 9, 2013 02:05 PM
EG-SIXV-TEC
Jun 14, 2013 08:22 PM
MelRon0529
Sep 12, 2011 04:11 PM
SOHC SPEED
Aug 27, 2008 01:03 PM
