no rev limiter? (head scratcher)
Old Mar 9, 2010 | 02:39 PM
teamjdm239's Avatar
Default no rev limiter? (head scratcher)
im on crome 1.5.3 tuning with a moates ostrich2 and i have the rev limiter set to 9,000, but its not registering that its on there.
i unplugged the emulator, restarted crome, then hit "read" to see if it saved. it shows the right rev limit, but it has no rev limit still. could this be a bad ribbon cable from the ostrich to the ecu?
Old Mar 9, 2010 | 02:47 PM
HRTuning's Avatar
Default Re: no rev limiter? (head scratcher)
The ECU wouldn't run normally if it couldn't read from the Ostrich. It'd be in limp mode. Are you really revving past 9?
Old Mar 9, 2010 | 06:32 PM
HamiltonRex's Avatar
try setting it to 7000 see if you hit it, then work your way up.
your tach may be off
Old Mar 12, 2010 | 08:16 PM
teamjdm239's Avatar
ad it at 8500 and it used to hit rev limit .but that was on a burned chip, and I got rid of the chip when i threw the ostrich on. I'm revvin to 9, and it shows 9 on the cluster, but there's no rev limiter.
Old Mar 12, 2010 | 10:25 PM
MONSTERek4's Avatar
set it to 9000 then click out of the box into another one then hit send crome is tricky like that
Old Mar 17, 2010 | 04:59 AM
teamjdm239's Avatar
i did. it shows a value like 9028 for the rev limit. but it still does not work?
maybe its the wiring to the ecu? but which wire could cause this from not having proper connection?
Old Mar 17, 2010 | 12:37 PM
mouab18c1's Avatar
Again try something lower like 8200rpm to actually see if it cuts off. Sometimes your cluster gauge could be off.
Old Mar 17, 2010 | 09:03 PM
teamjdm239's Avatar
im gonna try. thnx for the suggestions
Old Jul 16, 2014 | 11:13 AM
solosaniok's Avatar
did you found the fix for that problem? I also have this bug on crome 1.5.3 also on ostrich.
I also noticed that this happens when i add extra features like Launch an shiftlight.
Old Jul 21, 2014 | 06:40 PM
russian239's Avatar
offtopic: what does 239 mean in your nickname? Somehow I've got same 239 in mine
Old Jul 21, 2014 | 07:24 PM
Muckman's Avatar
Moderator in Chief
Do this.
Eh2Samuelian
Oct 24, 2015 04:43 PM
severaltony
Mar 15, 2012 11:23 PM
boostedNOTHARDLY
Dec 8, 2007 10:18 AM
turbocivic22
Apr 23, 2003 09:41 AM
