Intake cam gear bolt broke
Old Mar 9, 2010 | 01:43 PM
88aeFC3S's Avatar
Default Intake cam gear bolt broke
okay, long story short. i'm replacing my timing belt and accidentally over-torqued the intake cam gear bolt and the bolt broke off. now half of the bolt is inside the cam shaft.
- what do i need to do to be able to take out the bolt inside the cam shaft?
- how much does a replacement bolt usually cost?
Old Mar 9, 2010 | 01:47 PM
GagnarTheUnruly's Avatar
Default Re: NEED HELP, INTAKE CAM GEAR BOLT BROKE
Replacement bolts are probably cheap -- not sure what you can do about that camshaft, though. IDK if it's a good idea to try to drill it out. Maybe PB and vice grips if there's some thread sticking out. You may also be able to weld a nut onto what's left of the bolt and grab it with a socket wrench. GL.
Old Mar 9, 2010 | 01:55 PM
Hatorade's Avatar
What engine specs?
maybe its a good time for a camshaft upgrade?
Old Mar 9, 2010 | 01:56 PM
88aeFC3S's Avatar
theres no thread sticking out, so no go on the PB and vice grip idea. and i'm also debating if i should try to drill it out or just try to find another used cam shaft or something.
Old Mar 9, 2010 | 01:57 PM
88aeFC3S's Avatar
Originally Posted by Hatorade
What engine specs?
- 1999 B18B1
- all stock
- 165k miles
Old Mar 9, 2010 | 01:59 PM
I'd just get new a new cam. I bet you could find used LS cams super cheap. Going aftermarket might not be worth it for you if you're keeping her stock.
Old Mar 9, 2010 | 02:00 PM
Hatorade's Avatar
Originally Posted by 88aeFC3S
- 1999 B18B1
- all stock
- 165k miles
i'm sure it will be easier to just buy a used camshaft. stock ones are everywhere and in low demand.
alternatively, you could grab the Crower 62402 which will give about 10hp and stronger top end. they run around $300 i believe
Old Mar 9, 2010 | 02:04 PM
dntnedvtec's Avatar
Check on craigslist for some stock cams. Most guys will eventually throw in the bolt for the camshaft. the replacement bolt should be under 10.00. I paid almost 9 bucks for a tensioner bolt from the dealer.
I could be wrong but I think the cam bolt is tq down to 45 ft lbs.
Old Mar 9, 2010 | 02:16 PM
Jockone's Avatar
Remove cam and take it to a machine shop and have them remove whats left ot the bolt or get a used one which ever is most cost effective for you.
88aeFC3S's Avatar
yeah, im not planning to upgrade the head any time soon. i just need to get my car running...
HondaPartsHero's Avatar
Technical Hero
happened to me before, used this and it came right out
Old Mar 9, 2010 | 02:18 PM
dntnedvtec's Avatar
^ doesn't he have to drill a hole into the busted bolt? Then hammer that in right?
Old Mar 9, 2010 | 02:21 PM
88aeFC3S's Avatar
yeah, someone on another forum also suggested that idea too. where could i find one of those tho...maybe advance?
Old Mar 9, 2010 | 02:43 PM
88aeFC3S's Avatar
i think you drill a hole in the middle of the broken bolt then run the extractor in the hole. since it reverve pitched, it grabs the bolt and spins it out.
i just dont wanna **** up the threads inside the cam...
Old Mar 9, 2010 | 08:57 PM
dntnedvtec's Avatar
You should be okay, just dont drill the hole at an angle. Drill her straight. using the smallest drill to mate witht he extractor. Go from there.
Old Mar 9, 2010 | 09:04 PM
88aeFC3S's Avatar
thanks man. if i dont trust myself doing it, then i think ima just take it to a local machine shop to drill it out...
Old Mar 10, 2010 | 11:36 AM
88aeFC3S's Avatar
Default Re: Intake cam gear bolt broke
problem solved!!
carefully used EASY OUT and the bolt came out...
Old Mar 10, 2010 | 12:07 PM
95 integra's Avatar
BTW, LS cam bolts are 12mm (Vtec - 14mm) so they have lower torque specs and the bolts break much much easier.
Joe...
May 7, 2008 03:35 PM
Mugencrxsir1
Feb 21, 2006 02:55 PM
dblkack
Mar 16, 2005 05:24 PM
JDMlyfestyle
Nov 20, 2004 12:29 PM
JCCOOL43
Feb 12, 2004 11:56 PM
