mouting point for race harness?
Old Mar 9, 2010 | 12:03 PM
gosu08's Avatar
Default mouting point for race harness?
I am wondering where people mount their racing harness for their seat belts at?
I was planning on getting a C-pillar bar and mounting it there? I really dont know. I have had no experience with this nor has any of my friends.
If someone could post up pics of where to mount or just plain give me options on where to mount that would be great.
Old Mar 9, 2010 | 12:25 PM
get RIGHT's Avatar
Default Re: mouting point for race harness?
Make sure you ger an actual Harness bar. A C pillar bar is generally not strong enuff to act as a harness bar on is own.
For example: look into an Autopower 4pt.
http://www.safedrives.com/products.asp?cat=104
Old Mar 9, 2010 | 12:48 PM
gosu08's Avatar
what about a C pillar bar used with say miracle X bar or like a cusco cage? (i know not the best cage and etc )
also with it mounted to point D, can I still have passengers or will it be like having seats belts running above their heads if they were midgits?
Old Mar 9, 2010 | 12:54 PM
Doespike's Avatar
All of the above = ****.
If you're going to use harnesses, get a proper roll bar at the least. I also hope you have race seats and not trying to use the OEMs. Once you have a bar back there...the rear seats are just decoration...no passengers. No passengers even without the bar and just harnesses...unless you want to snap their necks in an accident
Old Mar 9, 2010 | 12:59 PM
gosu08's Avatar
yeah I understand. i dont really have passengers anyways. I just want a clean look for now as I might be entering the car in a car show if i can get everything bought in time.
On the picture, Point D, can two harness be bolted down there or only one?
Old Mar 9, 2010 | 01:27 PM
get RIGHT's Avatar
Just one per side.
Heres an excellent write up on this
http://www.sandmracing.com/ssabelt.html
Disclaimer: it is not safe to have all these bars insiade a street driven car. You should absolutely put high density foam covering these bars and wear a helmet while in use. It doesn't take much to crack your melon on a steel bar. And to add to what Doespike said, you will need to replace your seats with "fixed seat backs" for safety.
Old Mar 9, 2010 | 02:06 PM
Dave-ROR's Avatar
If you are planning on driving this car at expo it'll need to be stock, or have FIA seats, a 4 point roll bar minimum and 5/6 point harnesses.
Tesla220
Nov 29, 2009 07:44 AM
metal41mulisha
Sep 9, 2009 04:01 PM
Domo_Arigato
10
Jun 18, 2009 02:20 PM
Buttcrack
Mar 11, 2004 03:48 AM
Monkeydias
23
Feb 12, 2002 07:45 AM
