H2D CRX Si
Old Mar 8, 2010 | 09:40 PM
trulunacy2786's Avatar
Default H2D CRX Si
What's up H-T?! About a year ago exactly I put the H2D in my crx and absolutely loved it!! Well, I ended up selling the h22 to get the f22b sohc vtec because it has the iron sleeves. Then I found out how much internals would cost for the f22. So I'm putting another h22 into my car. When I ran last March, I hit a 14.18 @ 98mph. That was with a shitty intake, header, exhaust, rear mount, and clutch. This time around I'll have a better intake, better tune, 6 puck clutch, and a poly filled rear mount. I'm hoping to break 13's this Saturday. Mind you, the motor was and will still be internally stock. Another thing to note is that we're at 3,622 ft. above sea level so we lose about 1 second on our 1/4 et. Here's some pix of the crx with the h22 and then with the f22. I'll be taking more pix and record a video of the start up when I go to put it in tomorrow.
Old Mar 8, 2010 | 10:12 PM
prelude182's Avatar
Default Re: H2D CRX Si
wow, ive never heard of an h2d setup, thats pretty crazy. good luck with the quarter times and hopefully you can hit your mark.
Old Mar 8, 2010 | 10:18 PM
Thanks! I'd like to see how fast I can go with just tuning the suspension and building the transmission. After that, I'll start building the motor. Plans are to keep it all motor.
Old Mar 8, 2010 | 10:31 PM
skidmarkroyalty's Avatar
super short geared hybrid tranny with an h22 should be pretty ridonculous, might wanna look into it
Old Mar 8, 2010 | 10:35 PM
I wish I could get my hands on a JDM L3 trans and take the gear set from it. Get a 4.7 final drive and obx lsd, and I should be set as far as the tranny goes. Well, I could still strengthen the gears.
Old Mar 9, 2010 | 03:34 AM
beansandrice's Avatar
Clean up that engine bay homie. Other than that. It looks good and I Think you should be in the high 13s
Old Mar 9, 2010 | 06:44 AM
Yeah, I'm going to put the battery back in the rear. My fiance keeps trying to get me to do a wire tuck. I keep telling myself I'm going to do it, but in then I'll end up forgetting about it.
Old Mar 9, 2010 | 07:04 AM
fin781's Avatar
looks nice, but what is an H2D? ive seen the H2B's and there so sick. swap looks nice.
Old Mar 9, 2010 | 07:12 AM
H2D is a h/f series motor mated to a d-series trans. I like the fact that the d-series drive train is pretty much the lightest. I know it's not a huuuuuge difference, but I just have this thing about Power/Weight ratio. And for those of you that don't know, the d-series are actually stronger than the b-series trannies. The only weak point about the d- is the differential, but that is easily solved by getting an lsd installed.
Old Mar 10, 2010 | 12:03 AM
Here's a couple pix:
poly filled rear mount, adapter plate, 6 puck clutch, bisimoto balance shaft cover, explicit speed performance 1/2" over alternator brackets.
the two other pix are quite interesting. when i went to torque down one of the adapter plate bolts it broke. so now i have to wait till later this morning and hope that hedi calls me with good news.
at least now i have time to mount my bottle and possibly pull the dash out of my car.
Old Mar 10, 2010 | 12:19 AM
Deetz's Avatar
Crazy Honda Guy
hmmm, interesting....any proof of this???
Old Mar 10, 2010 | 08:58 AM
This is from the bisimoto website:
"Strength of the individual gears is also a big plus. Unlike their B-series bretheren, D-based gears are "stubby", and take well to abuse. "
Here is the link to the page where it talks about the H2D kit:
http://bisimoto.net/store/index.php?...x&cPath=3_5_25
Old Mar 10, 2010 | 09:29 AM
McGruber's Avatar
I have also heard that the d trannies are stronger than the b-series. F-series are where its at though
Old Mar 10, 2010 | 10:09 AM
88Hatchy's Avatar
PROOF - evidence establishing a fact or the truth of a statement
B series transmissions are superior to D series transmissions. For some reason Bisi likes them, probably because they bolt to his favorite engines.
Old Mar 10, 2010 | 10:20 AM
Just to be clear, his favorite engine is the F22 SOHC NON-VTEC. I'd like to see you tell that to Bisi himself.
Besides, I don't think you have enough experience with Hondas to confirm your statement. Bisi however does....
Go ahead and give Bisi a call: 888-922-6686
Old Mar 10, 2010 | 10:26 AM
88Hatchy's Avatar
^ D series fanboy
Old Mar 10, 2010 | 10:30 AM
^ D series fanboy
The same could be said about you.
Old Mar 10, 2010 | 01:01 PM
zsoccerdude17's Avatar
Can i be a B series fanboy?? please please. DOHC 4 LYFE
Old Mar 10, 2010 | 01:55 PM
i don't know i'd be considered a fanboy if i'm running an h-series motor with a d-series trans. im not hating on b-series. my friend's gonna be running the h2b in his integra. if anyone else feels the need to say something stupid, please don't. h-t has a **** load of dumbasses already, don't make it worse.
Old Mar 10, 2010 | 01:57 PM
For me personally and from expierience. We were blowing D series trannys on our 350 hp DOHC ZC turbo build back in 98. The car is still sitting to this day in my friends shop with a blown tranny. He is looking for the elusive D2B adaptor.
And yes he kept blowing Diff's. And yes d2b Adaptors exist.
Old Mar 10, 2010 | 02:07 PM
i mentioned that the only weakness on the d-series trannies are the diffs. replacing with an aftermarket unit will fix that.
Old Mar 10, 2010 | 03:32 PM
D2B adapter plate:
http://www.swapshopracing.com/conten...s/d696_01.html
wasn't very hard to find.
Old Mar 10, 2010 | 04:16 PM
Thanks for the link.
you look kind of mongolito in that pic!? lol
Old Mar 10, 2010 | 04:19 PM
lol, my wife made me make funny faces while she took pix. i need to change it though.
Old Mar 10, 2010 | 04:24 PM
Thats cool. Good build I want to see results! I want to see if that lil trans can take the H22 chingasos
