Old Mar 25, 2015, 11:50 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Burning Oil Smell coming from Engine Bay...
Old Mar 8, 2010 | 08:33 PM
MugenGTR's Avatar
Default Burning Oil Smell coming from Engine Bay...
I have a bone stock B20b motor and I keep getting an oil burning smell from the engine compartment. When I first start the car in the cold there is very light white smoke coming out of the exhaust but once the car is heated up there is no smoke at all from the exhaust. I have no CEL and everything on the car seems to be running perfectly. I replaced the plugs recently and they were a little on the white side (hot).
There is no smell at all from the rear of the car (exhaust). All of the oil burning smell is definitely coming from the engine compartment. If i pull the dipstick right after a long drive there is a little bit of white smoke that comes out of the dip stick hole. Also if I pull the PCV valve from the valve cover a little bit of white smoke will come out of that also. I checked the PCV and it worked fine (blew into it and sucked on it) but replaced it anyways just in case and the smell is still there.
Any idea?
Old Mar 9, 2010 | 06:05 AM
unusual71's Avatar
Default Re: Burning Oil Smell coming from Engine Bay...
did someone pour oil all over the engine when doing an oil change, that will cause the stink
Old Mar 9, 2010 | 06:09 AM
MugenGTR's Avatar
The oil hasn't been changed for awhile and the smell has been going on for about a good month now so I'm pretty sure if it were an oil spill it would've burned off by now.
I also check where I park the car at light and there are no oil stains so I dont think the engine is physically leaking either.
Old Mar 9, 2010 | 06:12 AM
negusjuda's Avatar
is it leaking oil? also how many miles on the motor. my car has the burned oil smell but im leaking oil. also i get the smoke when i first start the car but my valve seals are bad and im burning oil lol. i have 213k on my motor also but i get no cel light car runs fine. lost a lil power though it. could be either of those things
Old Mar 9, 2010 | 06:16 AM
MugenGTR's Avatar
My motor does not physically leak oil but it does burn a little bit of oil, i do have to top it off every month or so. The motor has around 135k miles on it. How do I test to know that it's the Valve Seals?
Maybe I should slap on a vtec head and call it day then...
Old Mar 9, 2010 | 06:24 AM
negusjuda's Avatar
yea it sounds like valve seals; typical for hondas lol. yea why not go for it. id replace bearings, rod bolts, rings, water pump, timing belt, and oil pump also while you have it open for reliability
Old Mar 11, 2010 | 01:37 PM
Str8EJ's Avatar
I had an LS which continuously dripped small amounts of oil from the oil pan to the exhaust b-pipe below. You couldn't tell by looking at it, but when I finally changed out the oil pan gasket, I could see the burnt residue of oil on top of the exhaust manifold section directly below.
Look for a small leak that might be getting intercepted by something hot before making it to the ground. Just a thought.
Old May 24, 2011 | 06:48 AM
1jdmem1's Avatar
i got aa dc2 wit b20v n it neva smelled like burnt oil n it started to after i race it like 4 times same day. but i notice my car dont have a thermalstat? smells like burnt oil from motor
Crvtec88
Jul 27, 2012 08:50 PM
TurboTeG4
Aug 10, 2005 02:49 AM
vince1990
Jul 27, 2004 03:25 PM
TheJuggalo
Jul 27, 2002 08:27 AM
vpforeva
Aug 30, 2001 08:08 PM
