Stripped Seat Bolt... Anyone?
I stripped the seat bolt when I was taking the seat for cleaning
and now the passenger side is secured by only 3 bolts..
steel bolts on aluminum, so I am thinking the thread on the chassis has been stripped..
any method to fix the thread? and what kind of thread is that?
Thanks
Thanks
just wondering..
while retapping the hole, should I choose the same size as the thread? or I have to go one-size larger?
The reason is because I want to stick with OEM seat bolts, is it possible to do this?
If the threads are more like non-existent, then you'll probably need to tap it out one size larger.
Northwestvtec
Jan 8, 2012 07:53 PM
