1997 Accord won't start
Old Mar 8, 2010 | 06:16 PM
terry s's Avatar
Default 1997 Accord won't start
!997 Accord LX, 4 cyl. non-vtech, automatic 150,000 miles has decided not to start. It turns over fine and has spark. It makes no attempt to fire. The timing belt was replaced several thousand miles ago and the camshaft turns. I do not have a fuel pressure adapter to check the fuel pressure. I loosened the banjo fitting at the fuel rail just a little. I got a healthy spray when the key was turned on.
Any help or ideas would be appreciated.
Old Mar 10, 2010 | 04:51 AM
terry s's Avatar
Default Re: 1997 Accord won't start
Last night I checked the main relay functions and all seem ok. Still have fuel pressure and spark will jump about 1 inch from coil wire or plug wires. I have pulse at the injectors.
Old Mar 14, 2010 | 06:57 AM
Nismode's Avatar
TRIAL USER
Knowing any mods that you may have would be helpful.
Old Mar 14, 2010 | 09:23 AM
terry s's Avatar
Thanks. Car is completly stock. The end cylinders have 30 psi & 80 psi compression. The center cylinders have good compression but have fresh oil in them. The car did not use oil and there is no sign of oil burning on any of the spark plugs. We have no idea what has caused this.
jdm_krish
Jun 19, 2018 07:40 AM
onthe3rdday
Nov 22, 2010 11:04 PM
DIABOLIC8
Jun 4, 2010 09:52 PM
13bROTARY
Sep 15, 2005 08:43 PM
StimpyBoy
Nov 16, 2003 09:35 PM
