'97-'99 Accord Recall
Old Sep 8, 2002 | 07:14 AM
EH3Kid85's Avatar
Default '97-'99 Accord Recall
Tried a search, nothin' came up.
I got a letter in the mail the other day from Honda that says
"Honda Motor Co., Ltd. has determined that a defect relating to motor vechile safety exists in the ignition switch on certain '97-'99 Accords. Electrical contacts in the ignition switch can wear prematurely due to high electrical current passing through the switch. Worn out ignition contacts could cause the engine to stall without warning. Although the engine will restart in most cases, if your engine stalls while driving in traffic or at highway speeds, you're at risk of being involved in a crash. Difficulties starting the engine (for example, hard-to-start, stalls immediatly after starting, etc.) may indicate that the ignition switch is failing"
Just thought i'd give you all a heads-up in case you didn't recieve one of these yet.
Old Sep 8, 2002 | 07:58 AM
Razor's Avatar
Default Re: '97-'99 Accord Recall (AccordKid85)
yeah almost everyone knows about this, thanks
Old Sep 8, 2002 | 08:02 AM
chotchkie's Avatar
well that would explain why i mysteriously stalled the other day.....
Old Sep 8, 2002 | 09:11 AM
oldskool_rex's Avatar
Default Re: '97-'99 Accord Recall (chotchkie)
yeah, this is something you will want to get taken care of asap.
Old Sep 8, 2002 | 10:20 AM
Accord94DX's Avatar
if you guys have any aftermarket alarms/remote starters, they will more than likely be disconnected in the process of installing a new harness. Just FYI.
honda genome
Mar 14, 2007 05:37 PM
honda genome
Mar 14, 2007 05:00 PM
anothervictum
Jun 3, 2004 05:42 AM
anothervictum
Jun 1, 2004 07:21 PM
anothervictum
May 31, 2004 06:22 AM
