B-Series Parts, Disc Brake Conv. (Central AL)
Sup guys. Looking to part out my would-be LSVTEC project I've had piling up for about a year now. I just don't really have the time to finish it, nor the money to continue investing. Just recently had a bit of bad luck and now I need some parts/money to get my Civic back up and going.
OBD2 B16A Head (complete) - $350
Head is disassembled but complete, will throw in a B16A intake manifold. The manifold does not come with fuel injectors or a throttle body as I do not have them. Also, no distributor. Head has about 60K miles on it Black valve cover.
OBD1 B18C GSR distributor (modified for an external coil setup) - $40
If you are purchasing the b16 head, I can throw this in as well for an extra $20 on top of the head price.
OBD0 B18A LS Block - $60
Got this from a junker. Never been cracked open. It is a mostly complete block in good shape, comes with flywheel and bolts. It has about 240K miles on it so it will obviously need a rebuild. The only thing it is missing is an oil pan, and the oil pump pickup needs to be replaced as it has some dings in it from loading when I purchased it.
90-93 Integra LS rear trailing arms with disc brake setups - $120
These are complete trailing arms (with bushings) minus the e-brake cables (I was going to order chassis specific ones). I was going to put these on my 92 Civic hatchback, but never got around to it. They are in great shape, the only things needing to be replaced are the brake pads and the rotors (they can be turned).
May have some other stuff to list when I figure out what I need to keep, etc.
All parts are available for pickup, as I don't exactly have a means to deliver them at the moment. Not looking to ship either. Prices are OBO, but I'm not looking to get lowballed... really need some money ATM. If I can get a camera, I'll post some pics. I'm located in Hueytown, AL which is just outside of Birmingham/Hoover/etc. PM me for details or to set something up.
As for things I need, looking for:
92-95 Civic front driver's side fender (2-DR or Hatchback)
92-95 Civic hood (2-DR or Hatchback)
92-95 Civic front bumper (2-DR or hatchback)
92-95 Civic driver's side headlight & turn signal
May consider trades for the above items with cash depending on what you want.
Thanks for looking.
Thanks for looking.
stockegsix
Northern California (Sales)
Jul 1, 2010 02:08 PM
