wiring da mirros in crx
Old Mar 8, 2010 | 02:10 PM
crazyboy's Avatar
Default wiring da mirros in crx
ok well i just got done installing da power folding mirrors i had laying around on my rex. i have the dx model which means no power mirrors. my question is how do i wrie the mirrors to be completely functional. somebody before told me i needed 2 universal relays and a legend heated mirror switch. i have access to all of the above i just need to know what wires go where. thanx in advance
pics of installed mirrors:
Old Mar 8, 2010 | 02:19 PM
lunalink's Avatar
Default Re: wiring da mirros in crx
whaaaaaaaaaat.
looks o.k what did you have to do in order for them to fit?
Old Mar 8, 2010 | 02:44 PM
crx_si-r's Avatar
Make it easier on your self and get the correct relay. As far as wiring it's pretty simple just color match the wiring if you have the actual plugs.
Or pm me I am making an extra power folding mirror harness at this moment, 90% done
Old Mar 8, 2010 | 02:53 PM
crazyboy's Avatar
Originally Posted by lunalink
whaaaaaaaaaat.
i just had to redrill the holes, but i still kept the old holes just incase i need to put stocks back on
Old Mar 8, 2010 | 02:55 PM
crazyboy's Avatar
well thats the thing, im broke lol, my money goes towards things i need not what i want. i have all these pieces laying around and i have nothing but time. and i just have the mirrors with pigtails. no plugs. theres also no wires to color match with because my car is set up for manual mirrors. also im pretty good a wirirng and reading diagrams, i put power locks on my non power lock da and it was pretty simple, this cant be much harder
Old Mar 9, 2010 | 10:33 AM
crazyboy's Avatar
nobody?
Old Mar 9, 2010 | 11:44 AM
Radim's Avatar
Aftermarket Relays aren't cheap, i'd say you just go to the junkyard and pull the entire mirror harness off a EF Sedan or DA (You can use the switch off a EF Sedan and it will OEM Accessory Slots)
Wiring Harnesses are like 15$ at Pick your part.
Old Mar 9, 2010 | 12:07 PM
crazyboy's Avatar
i have 3 universal relays in my garage, i dont neccesarily need them fully fuctional, just foldable for now. and here in modesto all the junkyards hondas are scavenged. could anyone tell me how to make them fold, with lets say universal relays and a pushbutton switch? thats all thats needed at this point until i get the mirror harnesses
Old Mar 11, 2010 | 12:38 AM
crazyboy's Avatar
somebody? help please, where fcm when u need him!?!
Old Mar 13, 2010 | 09:45 AM
crazyboy's Avatar
anyone?
Old Mar 13, 2010 | 10:04 AM
crx_si-r's Avatar
I pm'ed you, make it to sac and I'll help u out with wiring
Old Mar 13, 2010 | 10:16 AM
nycpatron's Avatar
i did it on my eks a couple of times with regular relays from autozone cost me like 9 bucks total to do instead of buying the oem ones that cost 80 bucks i had a diagram that i did myself let me know if you need help
Old Mar 15, 2010 | 12:01 AM
crazyboy's Avatar
ya bro i definately need help i have everything done but the wirirng to fold them. idk how to hook up the relay. i have a dpdt relay plz help
Old Mar 15, 2010 | 09:14 AM
99SiStyle's Avatar
eBay usually has all the stuff to get them to work.
*I have a set of power folding mirrors with all the wires, the relay and the switch if any one is interested. PM me*
Old Mar 15, 2010 | 09:15 AM
99SiStyle's Avatar
i might even still have the wiring diragram for them too on my computer
Old Mar 15, 2010 | 09:35 AM
crx_si-r's Avatar
For the wiring:
match all the colors. That's it. Then you have to splice the power wire to both mirrors (yellow/white wire).
For the power folding part. Wire 2 universal relays like you would do universal power door lock actuators. Then your done
Old Mar 15, 2010 | 09:59 AM
crazyboy's Avatar
does anyone have a diagram? ive only installed power locks once and that was by following a diagram. i have 1 spst relay and 2 spdt relays. which should i use?
Old Mar 15, 2010 | 10:30 AM
ef yu's Avatar
http://www.the12volt.com/doorlocks/page3.asp#arp
Old Mar 15, 2010 | 02:57 PM
crazyboy's Avatar
ok well i got the relays wired up with where do i put each wire that goes to the actuator? what about the lock wire and the unlock wire? i have 4 wires left on the relays, 2 actuator wires, a lock and an unlock
Old Mar 15, 2010 | 05:04 PM
crazyboy's Avatar
anyone know?
Old Mar 15, 2010 | 07:54 PM
crazyboy's Avatar
bump, pleze help, my cars torn apart and its not leaving the garage til its done... i miss driving it already
gnxpro24
Jul 5, 2011 01:48 AM
slkleltlclh
Dec 28, 2006 04:23 PM
notloudenough
Audio / Security / Video
Jan 10, 2006 09:13 PM
FourthGenHatch
10
May 28, 2004 04:43 PM
Hatchtrap
Mar 17, 2003 10:21 PM
