d16a6 versuzs sohc zc flywheel, clutch differential interchangeable
Old Mar 8, 2010 | 07:21 AM
acmoc's Avatar
Default d16a6 versuzs sohc zc flywheel, clutch differential interchangeable
Hi,
So My motor has gone. i'm going to get a new sohc zc
I want to get a 9 lb flywheel new clutch and lsd while I'm at it.
does anyone know if these transmission parts are the same? Between the two engines
Thanks
also, What;'s the difference between a stage 1 clutch and OEM
If I get a stage 1 will it not work well because I a, not making lots of Hp?
I think I make around 135 only
Old Mar 8, 2010 | 09:14 AM
acmoc's Avatar
Default Re: d16a6 versuzs sohc zc flywheel, clutch differential interchangeable
No one knows?
Old Mar 8, 2010 | 09:28 AM
Tyson's Avatar
whats the rule about SOHC ZC that everyone says... thats your answer.
Old Mar 8, 2010 | 10:55 AM
Sikocivic's Avatar
If you buy a 9lb flywheel with clutch it will fit both motors. Get one for the 92-00 Civic, its a bigger clutch and will bolt onto both motors. You transmission will fit fine as long as its 89 -91. 88 trannys have a different spline count.
READ the FAQs here. They will answer all your questions.
Old Mar 8, 2010 | 12:29 PM
acmoc's Avatar
I read the tranny part in the faq. But there was no mention of the sohc zc
The zc is the same as the 89-91 d16a6 even the tranny except the cam.
Is this correct
Old Mar 8, 2010 | 01:18 PM
acmoc's Avatar
Okay, Now i have another issue.
Should I get the OEM or stage 1 clutch
Is the stage 1 too loud or something for street use?
The car does get some time on the track
Old Mar 8, 2010 | 02:13 PM
acmoc's Avatar
That's my problem. are sohc zc's 1988 or 1989-1991?
Old Mar 9, 2010 | 04:35 AM
Sikocivic's Avatar
What tranny are going to use? Its the year of the tranny that makes the difference, not the motor.
Old Mar 9, 2010 | 05:35 AM
fireant's Avatar
I'm not so sure about this. Exedy sells the exact same model # clutch disc and pressure plate for both the 91 or 92 civics. The biggest difference is the throwout bearing (hydro vs rod).
Old Mar 9, 2010 | 08:24 AM
acmoc's Avatar
There's a gold sticker on my tranny. I'll go copy th numbers down
Old Mar 9, 2010 | 09:31 AM
Sikocivic's Avatar
I copied the link from the FAQ. It shoul tell you what you need to know.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/stock-clutch-fitment-guide-2284956/
Old Mar 10, 2010 | 06:52 AM
acmoc's Avatar
How many splines does the sohc zc transmission have
This is stamped on my tranny
L3-2545465
The 88 and 89-91 d16a6 transmisions are different.
Are the sohc zc 88 and 88-91 transmissions also different?
The flywhheel is the same, the clutch is what's different
Old Mar 10, 2010 | 07:56 AM
acmoc's Avatar
http://en.wikipedia.org/wiki/Honda_D...6Z5_engines.29
I hope this is true. The sohc zc is identical to the 90-91 d1a6
I'll order the flywheel/clutch kit and just get a clutch at napa if it doesn't fit
garageEF
May 13, 2007 07:24 PM
Creepshow S60
Nov 11, 2004 10:32 AM
SyKor33
Mar 31, 2004 02:01 PM
Ignitecivic
May 11, 2002 05:13 AM
Ignitecivic
May 10, 2002 10:47 PM
