2.1L BUILT MOTOR.
Old Mar 7, 2010 | 03:41 PM
ChrisEK9's Avatar
Icon3 2.1L BUILT MOTOR.
Im building a b20v setup to be on my DD car. and i want something reliable and that will last long. so im seeing what people opinions are as far as power, best cams to use, and how reliable it will be.
here it goes...
B20Z block 85mm
12:1 compression (with gsr head)
Eagle rods
ACL race bearings
B20 crank balanced and micropolish
Golden eagle 85mm head gasket
ARP head studs
ARP main studs (no girdle)
ARP rod bolts
OEM Type r Oil pump
OEM GSR water pump
Gates Racing timing belt
GSR head
Bronze Valve guides
Skunk2 springs and retainers
Skunk2 Intake Manifold
Skunk2 Cam gears
Skunk2 68mm throttle body
Skunk2 stage 3 tuner cams ( PLEASE GIVE ME YOUR OPINION ON CAMS)
Hy-tech replica big tube header
GSR tranny
ACT stage 4 6puck sprung clutch
ACT 8lb or 10lb flywheel. (cant remember)
Anyways i was told it should be in the 220ish as far as horse power and 12's all motor at the track.
Also what do you guys think of Skunk2 Stage 3 tuner cams? My tuner Colombian says they are great.
anyways thanks H-Tech for any advice given.
Old Mar 7, 2010 | 03:52 PM
Teamdiesel's Avatar
Default Re: 2.1L BUILT MOTOR.
I currently use those cams and made 249whp on a dynojet. The are ok cams but there are better.
Old Mar 7, 2010 | 04:07 PM
mar778c's Avatar
Community Builder
Community Influencer
Pro2s and Pro series VT would be your best bet.
Old Mar 7, 2010 | 04:08 PM
b20vtek's Avatar
i'm using them on my set up too and made 228whp car went 12.3 on my second pass
Old Mar 7, 2010 | 04:22 PM
ChrisEK9's Avatar
Wat compression do you have B20vtek? i would be happy with that for my DD car :D lol
Old Mar 7, 2010 | 04:58 PM
b20vtek's Avatar
12.5cr
Old Mar 7, 2010 | 05:10 PM
ChrisEK9's Avatar
mhmm not bad...pretty close....i noticed not alot of ppl go 85mm on here. i see a whole bunch of 84.5mm :-/
Old Mar 7, 2010 | 05:55 PM
b20vtek's Avatar
well i went 84.5 because a have stock sleeves and i wanted to leave some room just in case
Old Mar 8, 2010 | 04:12 AM
OH_1fstgsr's Avatar
Set-up looks great for the 220 target.
I would take a look at the Edelbrock Victor X I/M over the Skunk2.
Old Mar 8, 2010 | 11:31 AM
ChrisEK9's Avatar
i had a victor x manifold but i was told it be too much air so to trade it for a skunk2 pro...so hopefully that works out good.
Old Mar 8, 2010 | 06:07 PM
ChrisEK9's Avatar
bump for 85mm b20
Old Mar 10, 2010 | 05:38 AM
NY GsR's Avatar
Skunk2 tuner 3s ftw!!!
Old Mar 10, 2010 | 10:30 AM
koczeka's Avatar
Originally Posted by Teamdiesel
there are better
S2S3 changed to some Rocket
Old Mar 10, 2010 | 10:54 AM
BrokenEM1's Avatar
shoot, i would have stuck with the victor x and use a velocity stack at the track. Get a 70mm tb and port match it. If your running a stage 3 cam...come on...your gunna need a LOT of air, that heads gunna be suckin and puffin like a *****.
rsa0905
Oct 14, 2010 12:48 PM
ChrisEK9
10
Jun 28, 2010 10:12 PM
ChrisEK9
Mar 7, 2010 12:32 PM
JDM809
Feb 10, 2010 10:25 PM
Honda_Fanatic
23
Nov 9, 2007 07:54 AM
