Suspension & Brakes Theory, alignment, spring rates....
Brake pads to thick??
Old Mar 7, 2010 | 01:29 PM
Dann6968's Avatar
Default Brake pads to thick??
Bought some new pads and rotors for my 93 Si. Replaced the rotors and the pads but couldn't get the pads in the caliper to fit over the rotor. I had a caliper piston compressor (or whatever they're called) but I was still about a half inch off. The brake fluid filler cap was off.
Any ideas why this is?
This isn't my first time replacing pads but a first for the civic.
Thanks,
Old Mar 7, 2010 | 02:32 PM
randomtask77's Avatar
Default Re: Brake pads to thick??
The only thing I could think of would be is that 1.) is it the correct replacement brake pad or 2.) are you sure you compressed the piston far enough so that the pad could fit?
Also, I'm not positive on this as I haven't worked on brakes for the civic for a while, but isn't it possible to slide the caliper around so that you could fit it over the rotor with new pads?
Old Mar 7, 2010 | 02:54 PM
roastbeefrichie's Avatar
the piston must be fully compressed to fit your new pads
since you indiciated that you were unable to fully compress the caliper piston (1/2" off), i would inspect the piston for rust
you'll need to check that the caliper piston isn't seized. with the wheel off, i would remove the caliper brackets & keep the brake hoses ON. wedge a block of wood between the pads and very carefully push the brake pedal, which pushes the piston further out; look for rust that would cause the piston to get stuck. inpect the piston and the piston seal's condition
Old Mar 7, 2010 | 04:13 PM
Dann6968's Avatar
I was hoping this was going to be some stupid little thing I was over looking, guess not.
The piston is fully compressed - flush with the caliper body. I've looked at many different pads to make sure the ones I bought wern't unusually thick and that doesn't seem to be the case.
Don't want to but I might have to bring it to a brrake shop.
Thanks again.
Old Mar 7, 2010 | 07:51 PM
check the slider pins on the brackets, they need to be greased so they can move freely
http://www.hondapartsdeals.com/hpa_p...onGroupID=7348
CNelms
Apr 1, 2013 07:15 AM
BrakeExpert
Suspension & Brakes
Apr 9, 2012 05:59 PM
BrakeExpert
Suspension & Brakes
Sep 13, 2008 09:11 AM
classciv
Jun 25, 2004 04:07 AM
blkbeast
Jan 14, 2002 12:58 PM
