Suspension & Brakes Theory, alignment, spring rates....
Installing ITR rear sway bar
Old Mar 7, 2010 | 12:46 PM
caiboR's Avatar
Default Installing ITR rear sway bar
Got a USDM ITR rear sway bar and thinking about installing it to my 00 teg. Also gonna get a ASR reinforcement plate for the subframe. I'm assuming the sway should bolt right up or is there some other modifications? Is there also other subframe reinforcement brands other than ASR cheaper or equal in cost?
Old Mar 7, 2010 | 03:23 PM
Meoshe's Avatar
Default Re: Installing ITR rear sway bar
The Swaybar will bolt up with or without the asr brace. I know there is a beaks reinforcement kit out there, there is a F& kit as well. I think the Beaks might be the cheapest out of the three.
Old Mar 7, 2010 | 05:40 PM
98civdx's Avatar
Master Detailer
asr will work just fine, but the function 7 is really nice just more money, i belive comptech makes one as wel.
Old Mar 11, 2010 | 09:01 PM
caiboR's Avatar
thanks alot guys
Old Mar 13, 2010 | 11:04 AM
STOCK_SOHC_DX's Avatar
Cheapest isn't always the best. Beaks FTL!
Originally Posted by STOCK_SOHC_DX
Here is why
Old Mar 13, 2010 | 11:53 AM
sc34dc4's Avatar
That looksl ike the ek kit though. Never heard of any tear out at all on eg/dc chassis. People have ran them for years.
Old Mar 13, 2010 | 11:57 AM
GagnarTheUnruly's Avatar
This may be of interest to you:
https://honda-tech.com/forums/acura-integra-6/how-install-asr-subframe-brace-itr-sway-bar-dc2-integra-2729517/
Old Mar 13, 2010 | 01:00 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Probably the old Beaks EK kit. I believe they redesigned them for that chassis. I agree with the EG/DC Beaks kit being fine. I've had mine for over 5 years without a single issue.
Beaks works perfectly fine on Integras. Get the ASR if you want to combine the swaybar mounts with a tie bar and if you have the money. Otherwise just get the Beaks.
4thgenx42
Suspension & Brakes
Jul 24, 2007 08:43 PM
r1ch1e
Oct 14, 2006 06:42 AM
btdewitt
Mar 13, 2003 08:49 PM
96 SOHC VTEC
Jun 12, 2002 01:04 PM
RS_POWER
Jun 5, 2002 06:09 AM
