dsm 450cc injectors bogggg???
Old Mar 7, 2010 | 12:08 PM
h23vtec_dc2's Avatar
Default dsm 450cc injectors bogggg???
just wondering if this is normal for my boosted motor. i have a sohc zc in and obd0(pm6) ee unchipped/tuned, last week i put in some 440cc injectors i got from a past random turbo kit (kept the injectors, dont know the brand). starting off from first it bogs and rpm doesnt climb. also in gears it jumps and doesn't want to go. it was annoying driving cause i almost got hit from behind a few times and also in intersections. put back the stock injectors the next day and it runs perfectly fine.
so, recently just got some 450 dsm injectors, put them in and it didn't feel as bad as the first set but still pretty bad. at times it bogs starting off, so i have to rev the car up before starting (idling is rough too). so once again, drove back home and put in the stock and runs normal again.
my question is, is this a normal thing for an untuned obd0? do i need to add/do something or did i do something wrong?
Old Mar 8, 2010 | 01:45 PM
wmac's Avatar
Default Re: dsm 450cc injectors bogggg???
because 440cc injectors flow considerably more than the 240cc(stock) injectors, without the ecu compensating for the increase, i'd say you might be running kind of rich.
Old Mar 8, 2010 | 02:09 PM
shifty35's Avatar
Hell yes, it's normal for an untuned car to run rich as hell when you randomly put in injectors that flow twice as much. :D
Old Mar 8, 2010 | 02:41 PM
1990hf's Avatar
you're dumping way to much fuel with those injectors. you need to get it tune if you're gonna used them. plus you need a resistor box for the DSM 450cc.
Old Mar 9, 2010 | 10:35 PM
yea thats what i figured... and also wouldnt the stock obd0 civic resister box work the same way? or do i need the dsm box?
Old Mar 10, 2010 | 09:09 AM
raene's Avatar
Stock resistor box is fine with the DSM injectors. You just need to tune it.
Old Mar 10, 2010 | 10:01 AM
TheShodan's Avatar
Moderator
Do it soon, or you'll wash out the piston rings.
Old Mar 10, 2010 | 10:10 AM
mikej94civex's Avatar
would an apexi afc controller, tuned properly work instead of an actual tune? jw cuz i'll be in the same boat soon,
tuneless till i can afford it...
Old Mar 10, 2010 | 11:28 AM
raene's Avatar
Just leave the injectors out until you can tune.
Old Mar 10, 2010 | 12:12 PM
Turbo-LS's Avatar
the vafc is a hack, plenty of cheap street tuners that know enough to keep it reliable and be much better than a hack vafc
Old Mar 10, 2010 | 05:02 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
also you might want to smack your self just to make sure you don't hokey pokey anything else. get it tuned!
Old Mar 10, 2010 | 05:09 PM
lyncoors's Avatar
it will work but it will also raise your timing. but it will work fine if you have a wideband
Old Mar 10, 2010 | 06:44 PM
Turbo-LS's Avatar
AKA its a garbage hack dont do it. have a better fighting chance getting an ostrich and tuning your self not knowing more than 1.5 degrees per psi of boost of retard for a really safe tune that you dont have to worry about detonation
e30m3
Apr 3, 2009 05:52 PM
Sassafrass
Mar 17, 2004 06:30 PM
VanHonda
Sep 16, 2003 09:02 PM
Si2See
10
Jun 11, 2003 07:53 PM
