View Poll Results: Which for a GS-R build on stock IM (for now)
p28 ECU
28.57%
p72 ECU
71.43%
Voters: 21. You may not vote on this poll
Which ECU for my build: p28 or p72
Old Mar 7, 2010 | 07:33 AM
GagnarTheUnruly's Avatar
Default Which ECU for my build: p28 or p72
I'm doing a GS-R build (see sig. for a link to the build) and I've decided it's time to get a tune. My GS-R is a 96 so I need an OBD1 to tune. So far here are my mods:
AEM GSR CAI
GSR TB
GSR IM
GSR head stock port
Blox A cams and valvesprings
GSR header
GSR cat
Apexi WS2 exhaust
Fidanza 6.7 lb flywheel
First step for me is to replace the ECU and DIY tune it on Crome. I want to make sure my a/f is safe and get my redline and VTEC adjusted. Next I'll probably replace the header (SK2 Megapower or RMF replica if I'm feeling cheap) and cat with a high-flow cat. Later, I will replace the IM at some point with a single runner SK2 or PerfX, but that won't be for a year or two.
So, meanwhile, should I save the $$ and get a p28, or should I spend extra to have IAB control for a year or two.
Old Mar 7, 2010 | 07:36 AM
nokturnal_munkeeboy's Avatar
Default Re: Which ECU for my build: p28 or p72
since your not using stock cams i would have use p72, but since you have aftermarket cams use p28 with hondata s300
Old Mar 7, 2010 | 09:25 AM
AcuraIntegraLS-T's Avatar
If your going to run the stock gsr manifold us a p72 that way you can control the iab in the manifold the p28 will not do that.
Old Mar 7, 2010 | 09:57 AM
^^ Yeah, I know, it's just that I won't need IAB control forever, and I wasn't sure how much of a difference the long runners would make on my engine with a tune. I was hoping some people around here have run GSR IMs on p28s for a while and could tell me what it was like.
Old Mar 7, 2010 | 06:20 PM
Cuda4722's Avatar
Personally since you're going to be doing all that to your GSR, why not do an IM as well. Your power will only be improved over a stock GSR IM, and it will allow you to run the P28 too. The stock IM will only choke your potential power from the setup
Old Mar 7, 2010 | 06:55 PM
I'm getting a SK2 or PerfX IM and a 65 mm TB, but not until later because I still need a header and high flow cat and those will do more for my build at this time than an IM will. Cash is limiting so it'll be a while before the new IM comes -- a year or more.
Old Mar 7, 2010 | 07:31 PM
racebum's Avatar
the p28 or p72 are basically the same if you're doing a chipped tune. get the 72 since you need the iab function. once it's chipped they are more or less identical.
Old Mar 7, 2010 | 10:21 PM
seanbev24's Avatar
I ran the stock gsr manifold without the iab's hooked up and couldn't stand it for a week, let alone a year. Granted, this was without any adjustment to the vtec engagement, but I still think it would be worth the extra money to find a p72.
Old Mar 8, 2010 | 07:18 AM
I'll try unplugging the IAB and driving around, but it seems like p72 is the best bet. It's what my wife liked the sound of as well.
Anyone know of a good place to get socketed ECU's? I see there are a bunch of Ebay stores that sell them. The going rate for p72's seems to be about $200.
I just put a p72 vote for my wife LOL
Old Mar 8, 2010 | 07:22 AM
OH_1fstgsr's Avatar
I am currently running a P72 in my GSR. I used the IAB function on my PnP GSR manifold. This kept the midrange torque very nice.
One thing about my build was that I maxed out the IM at about 185whp, and then I changed to an Edelbrock Performer X. You won't max out your manifold probably until you change out your stock header for a better one.
Since you own an OBD1 P72, just use that. When you go to a single runner manifold, disable the IAB.
Old Mar 8, 2010 | 07:32 AM
My 96 is OBD2 unfortunately . If only my car was a year older...
I found this online:
http://www.jdmuniverse.com/forums/pa...tec-ecu-s.html
Seems like I can get a p06 converted to p72 chipped/socketed + conversion harness for $220 shipped. Seems like a good deal. Is there anything wrong with getting a converted p06?
Old Mar 8, 2010 | 08:49 AM
OH_1fstgsr's Avatar
Make sure your OBD2a>OBD1 wiring harness has the correct relay to work the IAB.
Your find seems pretty good. I don't agree with the sellers comment about the Performer X, so I'm a bit skeptical.
What about http://www.xenocron.com/index.php ?
Old Mar 8, 2010 | 11:08 AM
mouab18c1's Avatar
Im running a chipped p06 ecu on my 97 Gsr. Of course running an obd2a-obd1 conversion harness.
Old Mar 8, 2010 | 11:26 AM
Where'd you wind up locating your A/F gauge?
Old Mar 8, 2010 | 01:06 PM
racebum's Avatar
200 is steep. 100-150 has always been the going rate.
Old Mar 8, 2010 | 02:31 PM
mouab18c1's Avatar
I don't know where the hell people would mount their gauge with the mounting crap that I got from Xenocron which is Innovates product but I taped it above my steering wheel. Ill post a picture but I seriously have no idea how anyone could mount it with their mounting hardware.
Old Mar 8, 2010 | 02:58 PM
DDTECH's Avatar
Both ecus will need to get chipped and tune. doesn't matter which you use.. they are both the same.
Old Mar 8, 2010 | 03:21 PM
racebum's Avatar
if there is anyway i can nudge you into blox c cams and jdm itr pistons i really suggest it. you're looking at least at 20whp more and in a very broad rpm range. cost is minimally more.
Old Mar 8, 2010 | 03:42 PM
I think I definitely will upgrade cams at some point. What happened was that I was doing a timing belt install and saw it as a chance to swap the cams. I could get any set of new Blox cams for $335, but I couldn't afford cam gears and I knew it would be some time before I could tune. I went with the A's because I thought I could run my engine safely until I got a tune with stock cam gears (still only hit VTEC less than a dozen times since the switch). I also figured they wouldn't breathe well enough to lean me out as long as I had the stock header. After I can tune I'll get a header, cat and IM. Then I'll sell my A's, possibly for a profit, and get C's and pistons.
Old Mar 8, 2010 | 04:34 PM
racebum's Avatar
it's not so much breathing as it is compression. C's generally work best above 11:1 compression. use a single runner manifold and tune. 200whp has been had with the Cs & VT on a stock jdm itr more than a few times. dyno charts are in all motor. A's make similar power to itr cams and yes, with the 10:1 of a stock gsr aren't a bad choice. the blox c's are another knock off of the jun3 which is what the endyn bumpstix are also based on.
Old Mar 8, 2010 | 07:33 PM
silver_Ls's Avatar
p72 chipped is sexy
Old Mar 9, 2010 | 02:15 PM
P94dc4's Avatar
TRIAL USER
i have a gsr swap in my 95 ex. but i have a blox IM. and i have BC stage 3 cams bigger valves. and everything to build my top end. so which ecu would be better for my car? p72(i have on there now) or p28?
Old Mar 9, 2010 | 02:30 PM
The only difference between the p72 and p28 is that the p28 has the ability to control the intake air bypass (IAB) butterfly on the dual-runner GS-R intake manifold. All aftermarket IMs for Hondas use a single runner design, so they don't need IAB control.
You've got a Blox IM, so you don't need IAB control. A p28 would work fine for you, but there's nothing wrong with keeping your p72. The only issue is that p72s cost more, so from a money standpoint there's no reason to buy a p72 unless you have a GS-R IM. If you were going to buy a new ECU (if you need to switch to OBD1, for example), you should buy a p28 to save money, but if you've already got an OBD1 p72 you might as well just keep it.
mouab18c1's Avatar
Read the post made by All_Motor and you will have your answer.
Old Mar 9, 2010 | 02:45 PM
P94dc4's Avatar
TRIAL USER
ok ill just stick with the p72. thanks alot!
