wideband showing up as voltage in smanager?
Old Mar 7, 2010 | 04:00 AM
JRSC01GS-R's Avatar
Default wideband showing up as voltage in smanager?
I hooked up my plx wideband today and in the ecu the wideband is showing up as a lambda signal instead of a a/f ratio
the wideband is wired into eld circuit, and we played with the voltage offset tables and it didnt change anything
I guess I can do the math, but its kind of a pain in the ***, doesnt seem like it should be like this, anyone have any ideas?
Old Mar 7, 2010 | 08:23 PM
mtber's Avatar
Default Re: wideband showing up as voltage in smanager?
Double click on the AF value in the Sensors tab and select Air/Fuel UNIT etc...
Also go into parameters / closed loop and select the input you are using.
Make sure you removed the two resistors that the Smanager help file tells you to remove to use the ELD input.
Old Mar 8, 2010 | 06:30 PM
JRSC01GS-R's Avatar
thank you for the fast and on point response, that was exactly the info i needed
Old Mar 9, 2010 | 06:41 PM
mtber's Avatar
No problem!
Max500
Engine Management and Tuning
12
Oct 16, 2011 09:12 AM
josh green
Mar 28, 2010 11:04 AM
terenceng
Feb 28, 2010 09:14 AM
rough_draft
Jan 11, 2005 08:48 PM
SuperTeg95
Jan 28, 2003 11:15 AM
