WTB: B18b Engine Harness, Timing belt, Virgin P28
Hello,
I'm looking for:
B18b:
Engine Harness
performance Timing Belt
Aftermarket Cam Gears
Single Crank Pulley for just Alternator belt, not the 3 slotted one
Misc:
Virgin P28 ECU
LMK What you got and i'll hit you back.
I'm looking for:
B18b:
Engine Harness
Misc:
Virgin P28 ECU
i'm not really good with buying things that we don't know where there from, if you could figure out if its from an obd1 motor, which i'm pretty sure matters for ecu's, thaaaan i'd be glad to talk with you.
and no the engine harness doesn't matter OBD1 or OBD2 for a B18B IF it is being run in an EG/DC since the ECU connectors are in the cabin area and NOT attached to the engine harness. Distributor, injectors, and alternator connections are different also! EK's well that is a different situation since the harness is 1-piece instead of 2-piece...Maybe you could let the rest of know what YOUR set up is so we all can get you the parts you need??
Oh and I fixed your grammar too...
kevs-ej1
Aug 12, 2009 03:17 PM
reaction360
Aug 10, 2003 12:15 PM
