Skunk 2
The Skunk2 Pro intake manifold is CARB legal. Tuner Stage 1 cams are too. Stage 2 and above, no. Throttle body? I don't think so, but they post here every so often...they may correct me if I'm wrong.
fm
fm
From what Cali sounds like, unless the number is easily seen or the part can't be seen, you'll just have issues...assuming the police aren't just being jerks and ticketing you because the car is Japanese.
Stage 1 cams are usually going to be like Type R cams. More aggressive than that and the longer overlap and such will probably create higher emissions.
