help w/ check engine light
Old Mar 6, 2010 | 06:41 PM
jjenkins's Avatar
Default help w/ check engine light
okay i'm stumped, check engine light came on couple days ago and i read the code said some **** about o2 sensor.. so i went out and replaced both o2 sensors, cleared the code w/ the codereader, unplugged my ecu, unplugged my battery.. it was good for maybe 5 minutes then cel came back on with same code it said something like
O2 Sensor Circuit Low Voltage 1
any ideas?
Old Mar 6, 2010 | 07:46 PM
b1u3_5i's Avatar
Default Re: help w/ check engine light
circuit low voltage means the O2 oxygen sensor's voltage remained low for longer than 2-3 minutes. check for plugged catalyst, short to voltage on O2 signal circuit and high resistance or open on O2 signal circuit. possible kinked wire.
Old Mar 6, 2010 | 07:48 PM
jjenkins's Avatar
i think your signature is perfect for this situation, care to explain what i need to do to take care of the problem?
Old Mar 6, 2010 | 07:59 PM
b1u3_5i's Avatar
start by checking if your catalyst converter is plugged/restricted. an exhaust leak could also play a roll in this situation. What bank is the fault showing? If you have a volt meter and a helm manual, follow the flow chart. I do not have it on the top of my head right now but check for the proper ohms and voltage you should have at the plugs, ecu and circuit.
Old Mar 6, 2010 | 08:05 PM
b1u3_5i's Avatar
or you may take it to a specialized tech for a proper diagnosis, then change the part yourself. it beats throwing parts at it. just my .02
Old Mar 6, 2010 | 08:37 PM
jjenkins's Avatar
for sure man thanks for the advice i appreciate it
IP RACING
Jan 29, 2008 06:53 PM
Mad Money
Sep 27, 2006 08:22 AM
want2rally
Oct 9, 2005 09:37 PM
951dc5
May 29, 2005 04:39 PM
