Another auto trans issue!
Old Mar 6, 2010 | 04:24 PM
GuCBlackEk's Avatar
Default Another auto trans issue!
I had to purchase a new shift cable and it was installed tonight. However, when I'm in the car the shifter moves freely, I dont need to press the brakes to release it. The cable works as it pulls the leverage while shifting from P to D, etc. Any ideas?
Old Mar 7, 2010 | 02:43 PM
talkerty's Avatar
Default Re: Another auto trans issue!
So there is no resistance to change through the gears? I am thinking there might be something wrong with the linkage under the shifter.
Old Mar 7, 2010 | 03:28 PM
shogee's Avatar
i think you probably forgot to hook up a wire connector, sound like you have no shift interlock, for like when you have the engine running and you step on the brake and then you can shift into gear.
wagovan guy
Dec 28, 2014 07:12 PM
StevenGladstone
Aug 2, 2008 02:22 PM
90LSpimpin
Mar 1, 2006 07:13 PM
90LSpimpin
Dec 7, 2005 01:55 PM
