help with block specs *searched
for some reason my login to alldata isn't working...
i need some block specs for a 91' b18a1 that i'm sitting in front of.
main journal bore size
crankshaft main journal diameter
rod journal bore size
crankshaft rod journal diameter
rod bearing oil clearance
main bearing oil clearance
i'm trying to setup oil clearance using an eagle lightweight 89mm crank. theres no markings for bearing selection on an eagle crank... or else i'd code the bearings.
many thanks to whomever can help
Main journals except #3: 2.1644-2.1654", #3: 2.1642-2.1651"
clearance except #3: .0009-.0017"
#3: .0012-.0019"
rod journals: 1.7707-1.7717"
clearance: .0008-.0015"
rod bores: 1.89"
wrist pin bores: .8255-.8260"
im on mitchell and im not seeing a main bore spec.....just the journal spec.
#3: .0012-.0019"
rod bores: 1.89"
killerpenguin21
Jul 23, 2006 12:42 PM
1 Cam Wonder
Jan 24, 2005 08:29 AM
