For those of you with 17" wheels....
what offset are u running? I might be buying a set of volks in 17" but Im not sure what offset I should get. Hell I dont even know if I should buy 17's or not. But I dont want to have to worry about rubbing the fender or inside the wheel well. Im guessing like a +42 to +45 would be ok??
+42 on mine. Handling is ok but my stock15s with poorer rubber handled better. I get a bit of tramlining on the brakes and if I lower the car the rear arches will have to be rolled to avoid rubbing. Not sure if the fronts will need doing as well. I'm really should have got 16s. Hope this helps
KashMillien
Aug 19, 2015 07:12 PM
MikeD
Jul 24, 2001 09:05 AM
