Ever have a bad crank sprocket?
Old Mar 6, 2010 | 10:04 AM
5thgen's Avatar
Default Ever have a bad crank sprocket?
I just bought a motor (b18b / didn't get to see it run) and everything checked out with it except a wobbling crank pulley. I switched it out with my other, half-running car (with no wobble from the crank pulley at all) and it still wobbled.
So...either the crank or a big maybe on the sprocket?.....I took the obd2 sprocket off and replaced it with the obd1 style (plate - sprocket - plate - pulley) and it looks like it took the wobble out.
Anybody else experience something like this? I wouldn't expect a crank sprocket to get out of shape....I guess weirder things have happened.
here is the sprocket
Old Mar 7, 2010 | 04:11 PM
postman's Avatar
Default Re: Ever have a bad crank sprocket?
how exactly did you tell or determine the crank sprocket was wobbly with the engine running. visually its that bad?
DARKTEG_
Aug 13, 2006 03:15 PM
RAB
Oct 13, 2004 05:45 PM
flat-blk-HB
Jan 13, 2004 07:26 PM
vtec69
16
May 18, 2002 04:04 PM
