90 Honda CRX Si with JDM B16a - Motor Mount Bolt question
As the title says, I have a 1990 Honda CRX Si with a 1st generation jdm b16a swap. Not quite sure if all the extra details was needed but just in case.
Basically I am wondering if I can order the "bolt" that connects the rear motor mount to the K bracket from Honda or an Acura dealership.
Not quite sure if anything changed, as it was just a swap. So do I order the regular CRX rear motor mount bolt? Or do I have to order an intergra motor mount bolt?
Just verifying. ANy help is gladly appreciated. "Tired of breaking axles".
if you have the old bolt just go to your local autoparts store to see if they have it...i had the same problem and same swap(mine a 91) and they had the same bolt or a equivalent size bolt...hope this helps
i think they r the same... i would go to magistic honda and c if the part # r the same.... if not than order the integra one...
Only problem is that I don't have the bolt. Installed another b16a transmission. Basically the bolt was left out even though I reminded it to go back in.
Honestly I think it was stolen.
Everything works great but any additional help with the bolt would be appreciated as I don't know what size or diameter or anything of the sort.
Stay away from the auto parts stores those are grade 5 hardware JUNK!
What I would do is go to a junk yard and get the bolts. Or get on to www.hondaautoparts.com and order the mount bolt if its the one that goes through the end of the t-bracket its a ""long bolt"". If you need the two shorter bolts on the t-bracket just order the trans to engine block bolts there all the same on cable b-series
http://www.hondaautomotiveparts.com/...5=ENGINE+MOUNT
Order Two of #20 for the short bolts
For the long #34
For the long #34
It is the bolt that matters. The bolt that goes through the middle of the bracket and motor mount. The bolt that attaches the motor and bracket together.
Like this picture. This picture is not a honda car picture but obviously the bolt in the middle of the red bushing part of the motor mount is the one I am refering too. A good picture to tell.
Thanks for the help everyone, if we are on the same page, or atleast now, any other info would help.
So you are saying the bolt that goes through the middle on each motor mount are the same? The long bolt? If all b series were the same I could just get an integra motor mount bolt?
Forgot the picture, here it is. And no, this is not a honda or acura car. I am just providing an easy way of showing the bolt I need. Same setup. The silver bolt with the green slashed on it in the middle of the red bushing of the motor mount is what I need for the rear motor mount of my b16a.
Thanks for the help. I'm guessing you are saying the bolt is the same as a b16 civic? i hope so. Thank you all very much. You helped me out a ton. Going to order it.
Well, I got it hooked up and all is good in that part.
But it seems that the other side of the bracket is not hooked up to the block too. I provided a picture of the rear bracket I have with my b16a swap.
I think my brack looks like the GSR one in the picture. Not quite sure I cannot see too well.
Anyways I need the bolt that hooks up to the block now which I circled in the picture I provided.
Do I pick up a GSR or LS bolt or a 99 civic si? This is quite a pain now haha. Any help is gladly appreciated.
I'm guessing nobody is too sure? I believe the bottom bolts to the bracket should be enough but if any case, am I wrong? Should I hook up the only bolt remaining?
If I do need the bolt, what would a 1st generation jdm b16a bolt compare too? I understand that all b series are the same, but I'm not gonna suggest that everything is exactly the same, is why I'm asking.
Any additional help is helpful
90-93 LS is the bolt you need
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Item 25
Item 25
Item 25
Item 25
nicob
Honda CR-V & Element
Feb 27, 2019 01:09 PM
