SRS light on
OK Guys I left My Head Lights ON By Mistake For a Couple Hours
Came Back Car Didn't Wanted to start so i Put The Battery Charge for About 2 Hours Car Start Perfect But Now My SRS Light Stays ON Any Help Plz
95 Accord LX 4 Doors Auto Trans
Theres a thread that has most of the basic questions anyone could need.
https://honda-tech.com/forums/honda-accord-1990-2002-2/1990-2002-accord-faq-1664547/
Under clearing SRS light.
https://honda-tech.com/forums/showthread.php?t=1664547
i had mine come on, randomly on and off for a while. clearing didnt work, then i used ethos to diagnose it, i have short to power on drivers side airbag. if your lucky like me u should take it to a friend that has something to diagnose obdII and do it for free lol. didnt have money to fix it so i jus pulled the bulb out bc inspection was comin soon
I have the procedure in my Bypass SRS Light FAQ
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-bypass-srs-aftermarket-wheel-2398113/
It's quoted in there, first post
Correct - I should have clarified the RESET procedure is detailed in that thread.
That bypass wouldn't work regardless as it only bypasses the driver's side airbag. If the SRS light is on for any reason other than that the resistor fix is worthless.
Any other reasons then why the SRS would be on if someone has tried resetting by disconnecting battery and checked fuses. Mine came on after I connected my subwoofer. I think I might have made accidental contact and blown something. My guess would be the srs module itself. Do you have any other suggestions or tips what else I can do? Thanks
Thanks Muffin. I'll double check everything this weekend to make sure.Also found this
An SCS Service Connector is used to reset your SRS light, which every Honda owner will eventually end up having to do. The dealer charges anywhere from $65 to $95 to do this, I'll show you how to do it for under $10.00. First you need to go to Best Buy or Circuit City and pick up some late model Honda speaker harnesses by Metra. The Metra model number is 72-7802. Cut the female disconnects off the ends of the speaker harnesses and strip about a half inch of jacket off of the wire. Twist the wire together and tape up the bare wire, you now have an SCS Service Connector for quite a but less than what Honda would have charged for one.
Now I'll show you how to reset the light. We've allready done the 1st step by making the SCS Connector.
You'll need to find the MES (Memory Erase Signal) connector.
It is a yellow connector with two wires in it that is plugged into the back of the driver's side fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. Here's a diagram for clearer understanding.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
It worked first time for me. If it doesn't work first time, try again. The timing has to be pretty precise. Doing it with the connector I made is much easier that using a paper clip to jump the connector. Good Luck
Found this helpful information previously posted on here
its not working for me either, my SRS has been on for a longggg time too, and I haven't done anything to provoke it, or so i think.
