FOG light wiring help
Old Mar 6, 2010 | 06:57 AM
Rheg6's Avatar
Default FOG light wiring help
where do you run the fog wire in an rsx INTO the car ?? i see no openings at all for a wire to run into ... the only rubber grommet i can see that i can run it into the car is the one on the drivers side fender so would i have to run them into the fender ??
Old Mar 6, 2010 | 05:22 PM
Rheg6's Avatar
Default Re: FOG light wiring help
bumpppp
Old Mar 6, 2010 | 07:11 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
is it aftermarket? Not OEM?
Old Mar 6, 2010 | 07:26 PM
Rheg6's Avatar
yessir aftermarket but OEM style i believe ??
Old Mar 7, 2010 | 12:41 AM
rjmq06's Avatar
lol is it from the dealership or from somewhere else?
cause ebays are crap nothing beats the oem but aftermarket ones are ok too if you dont mess it up
Old Mar 7, 2010 | 04:54 AM
Rheg6's Avatar
not sure its not mine just installing it for someone .. but anyways where does it go into either way ?
Old Mar 7, 2010 | 07:04 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
well if they are OEM the lines are already run! There is a connector in the engine bay and a connector in under the dash you connect to.
Type-Spaz's Avatar
DC5/EP3 MOD :)
cause are you talking about wiring from the switch to the fog lamps?
Old Mar 7, 2010 | 07:07 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
if you sign up for my clubs website you'll see my DIY
http://www.urbandisturbance.net/foru...read.php?t=594
Here is the brown clip held on with blue tape
There is another brown plug with blue tape next to the fuse box
Old Mar 7, 2010 | 05:41 PM
Rheg6's Avatar
i signed up and looked i still dont understand how it goes lol
Old Mar 7, 2010 | 07:50 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
ok well tell me which part your having trouble with
Old Mar 8, 2010 | 02:05 AM
rjmq06's Avatar
damn i need a tutorial too LOL
im still having trouble with my ebay fogs wiring
i i followed all the instruction as describe but i mess it up and burned my cluster now that my cluster has been fix im scared to burn it again if i touch it
by the way i drive a ep3
Old Mar 10, 2010 | 06:43 AM
sicky's Avatar
grammer nawzi
clubrsx has a great write up that involves just hooking it up to the lights. Whenever you turn your parking lights on they will turn on. not sure if you want to be able to manually control the fogs, but this is the easiest way i have seen.
Old Mar 10, 2010 | 07:58 AM
Rheg6's Avatar
yea i want it switched on only when i want to it ... trying to figure out how i can run the wires INTO the car ... lol bumppp eveyrthing is already on just the wiring is not done because im not sure where to run it into the car only the drivers side fender has a rubber grommet to run it into
Old Mar 10, 2010 | 02:16 PM
speedengineer's Avatar
When I did my ebay fogs, I didn't have to run anything through the firewall. The foglight harness simply plugged into the brown connector as shown in the pic from type-Spaz. All you have to do is wire the rest up inside the car.
You need to tap into accessory power to power the switch and relay. This makes it so that when you turn the key off, the fogs go off even if the fog light switch is still on. Then all you need to do is wire the output of the relay over to another one of those brown connectors which is up under the dash near the fuse box/steering column. This connector sends the 12v from the relay through the firewall to the other brown connector where you plugged in the fog light harness too. That's it.
Old Mar 10, 2010 | 09:06 PM
Rheg6's Avatar
iono if it will make a difference but im doing it on an 03 rsx
Old Mar 10, 2010 | 09:36 PM
'02 rsx here. Same thing. You won't need to run any wire through the firewall. All you have to do is set up your switch and relay under the dash so that when you turn them on, 12 volts is applied to the brown connector under the dash, which sends power through the firewall to the brown connector by the washer fluid tank, which powers the fog light harness.
Old Mar 11, 2010 | 06:12 AM
Rheg6's Avatar
alright ill give it a shot once again ill update you guys if anything
dapdabbin
Nov 22, 2012 12:40 PM
civicpraning2k1
Honda Civic (2001 - 2005)
Jan 4, 2011 05:59 AM
superchargedY8
Lighting
Apr 21, 2009 10:15 AM
SargentNg
Mar 18, 2005 08:49 PM
hyper em1
Sep 24, 2003 12:21 PM
