CA BUILT Interga DA9 f/s f/t
FOR A FRIEND:
4800 with wheels
4300 without wheels
1991 Integra Ls
CLEAN title
Power Everything, COLD a/c.
148k miles on the chassis less than 4k on motor
Smogged, tagged, registered.
Engine "Poor Man's Type R" Build ($3700 parts, labor, dyno, etc):
Fully built b16 head with semi built block
Skunk2 Pro series cams
Titanium valve springs and retainers
Valve job
Skunk2 IM
Gsr Block with:
Type r pistons, rods and crank
Type r oil pump
10:8:1 compression
3 piece headers
550cc injectors
Jdm b16 tranny
Exedy Stage 2 clutch
Fidanza 7lb Flywheel
Converted to obd-1
DYNO Tuned, made 204whp 141wtq (car is light so it will easily break 13s even with a bad driver)
Interior:
Stock oem Ls CLEAN
interior is MINT only one rip on driver seat
power everything everything works
Exterior:
no dents or major dings
One scratch on rear driver side panel
original paint is slightly fading on roof
Wheels:
real mugen rnr's with falken azeni new tires (note:will be sold on bronze ekei's)
tein lowering springs
drilled&slotted brakes with brembo disks/calipers
CONS: oxidation on roof but can be easily buffed out
I personally can vouch that this car is pretty quick. It has pulled on g35's, camaro ss's, mazda speed's, kpro/bolted rsx type s, evo's (all with unknown mods, probably stock.) & countless random honda's.
As for trades (need to be in the 5k range) my friend is very intereted in getting into a rwd car such as a nissan s13 or s14. Also honda trades if they interest him enough so shoot your offers. Primarily a eg hatch. Cash on your side if needed.
DO NOT PM for more info or pics call/text my friend anytime 951 534 4454
Located in: So cal I.E.
4800 with wheels
4300 without wheels
1991 Integra Ls
CLEAN title
Valve job
Skunk2 IM
Gsr Block with:
Type r oil pump
10:8:1 compression
3 piece headers
550cc injectors
Jdm b16 tranny
Converted to obd-1
Interior:
Stock oem Ls CLEAN
Exterior:
Wheels:
yes my friend is looking for trades, he would prolly want cash on top for a sohc though unless it was very clean. glws.
thanks, I think so too.
you evidently are new to ht... welcome. its called an avy. & she's my gf thanks
well just hit up the # listed & u can ask him yourself
to the best of my knowledge its a gsr block with type r pistons. if you want a more accurate answer to any questions about the car simply call or text my friend at the # listed in the post. i simply posted this for him because he asked me to.
NOTE(again): This is NOT my car, it is my friends. & if you have any questions about the build and/or anything technical simply call or text my friend's # which is listed at the top... Thank you.
