Hickam's 2010 K24 Turbo Hatch
Here is my setup for 2010. Been working on this hatch for a while but have had a few other projects that got in the way. Going to start tuning at 8lbs then try to hit 22-24psi.
Basic Run down
K24a2 bottom end
K20 head
JE pistons
Cunningham rods
ERL Superdeck 2 sleeves
Excessive bottom feed mani
75mm mustang TB
3" IC piping
Comp Turbo 67mm
Twin 44mm
Mani, downpipe, dumptubes, intercooler piping, catch can and lots of other stuff made by me
50mm bov
Precision 1600 cc injectors
FJO injector driver
Twin Bosch 044
Wavetrac LSD
ALBINS gears thanks to Erik at Bullhead Gears!
Sorry for the crappy cell phone pics. Will have some new ones up within the next few weeks. Going to start the car and start doing basemap this weekend.
There is still several things that I would like to do but I am anxious to get it running down the track!
Basic Run down
K24a2 bottom end
K20 head
JE pistons
Cunningham rods
75mm mustang TB
3" IC piping
Comp Turbo 67mm
Twin 44mm
50mm bov
FJO injector driver
Twin Bosch 044
Wavetrac LSD
Also got the car running right last night. The Stant 180* thermostat wasnt opening even at 210*. Took it out and it opened in boiling water. Went ahead and left it out to make sure that was my problem. My fan also wasn't turning on but when I took the thermostat the fan came on. Sucks that I double checked all of my k series conversion harness when I had it all hooked up right the first time.
Just need to do a few more things so I can take it to get it tuned.
Dumptubes
4" aluminum exhaust
bleed clutch and brake lines
move the fpr and run a 4" intake tube for the turbo
Dumptubes
4" aluminum exhaust
keep up the good work
