dash lighting wtf
Old Mar 5, 2010 | 04:33 PM
luckyknuckles's Avatar
Default dash lighting wtf
i installed a new headunit and now my dash and gauge lights are on when my headlights are off, and then the dashlights turn off when my headlights are turned on...wtf
Old Mar 5, 2010 | 04:38 PM
philadd's Avatar
Default Re: dash lighting wtf
Sounds like you connected the wrong wire to the car's "illumination" wire. Did you use an aftermarket wire harness to connect to the OEM plug, or splice into the stock wires?
Old Mar 5, 2010 | 04:40 PM
stock wires were already cut so i had to splice into factory..
Old Mar 5, 2010 | 04:44 PM
stock wiring combined illumination and dimmer in a red and white wire.. head unit had two wires.. is it possibkle my problem is from leaving either the dimmer or illumination unspliced
Old Mar 5, 2010 | 05:15 PM
redbull-1's Avatar
It probably has to do with the illumination wire. How exactly are you hooking up the illumination wire, I'm a little confused?
On aftermarket radio connectors, there is an orange illumination (dash light dimmer) wire that many people don't use, it should be taped up.
Old Mar 5, 2010 | 05:22 PM
the car has a red/white combined wired for the two... i believe there was only an orange and white wire which was labeled dimmer that i hooked to it... no orange illuniation wire.. are they seperate or am i an idiot
Old Mar 5, 2010 | 05:33 PM
redbull-1's Avatar
Try this:
Disconnect the red/white from the orange/white dimmer wire. It may not be necessary. If it is okay after that, tape up the orange/white dimmer wire.
MilanoLude
Mar 19, 2007 03:26 PM
deucedeuceEK
Jan 15, 2006 07:40 PM
JDM tuning702
Nov 21, 2005 11:56 AM
type r 01-1063
Dec 13, 2003 06:08 PM
rafimos
Audio / Security / Video
Nov 5, 2002 09:01 PM
