Fully Built All Motor B18A1
The current fully built motor that is in it ($10K in parts and $6K in labor have papers to prove it)
(Fully cleaned, gasket match ported intake, gasket match ported exhaust/polished, polished combustion chambers, gasket surfaces cleaned, Super tech valves, springs, retainers & valve seals
valve clearances checked
head milled .030
3 angle valve job
Crower Stage 2 403 camshafts
Crower polished camgears
ARP Head & Main studs
Gates Racing timing and supertine belt
MSD Extreme Distributor Cap 82922,Rotor 8092,
Wire Set Extreme 8.5MM 35329
Golden Eagle Fuel Rail (Blue)
Skunk2 Pro Series Intake Manifold
RC Injectors Fully rebuile OEM's
All Cometic gaskets
Injen Intake
The Block:
Mahle 81.25MM 10.5 Compression Pistons, rings, & pins
Bored over .25 MM
BILLET CROWERODS ACURA INTEGRA 1.8
Moroso Oil Pan
ACL Race main, rod and thrust bearings
Cometic Full Gasket kit C4388 & Head gasket C4238-030
ARP rod bolts
Fresh Hone
Block Completely hand cleaned
Ralco RZ Single Belt Conversion Crank Pulley (Alternator only)
Aasco Lightweight Flywheel (8lb)
Exedy Stage 2 Clutch & Pressure Plate
Raxles Custom All Motor/Autocross SCCA Axles
Brand new Desno alternator
All royal purple fluids (currently break in oil)
Full 2.25 Stainless steel exhaust
Vibrant Performance Street Power Flat Black Muffler with 3" tip 2.5" in/outlet
LSD YS1 JDM XSi Trans
Fidanza Short Throw
Energy suspension shifter bushings
Flow numbers are as follows
Intake Exhast
Lift: 100 150 200 250 300 350 400 450 500 100 150
CFM@ 28in 69 105 147 166 180 194 207 218 224 62 111
127 151 164 173 175 176 178
1 angle
CFM@ 28in 76 116 159 187 194 203 213 221 225 67 99
135 161 171 176 176 176 176
3 angle
Backcut angle
Checking stem height 2
Exh seat pitted
Exh valve 2 seat marking
Left exh. seat ground
Flow bench 2
Grinding stem tip 2
grinding backcut
Head resurface 1
head resurface 2
Int seat 45 ground
Intake Angles 15, 45, 60
Intake seat 45 & 60
This is how the flow numbers finished on test 3.
Intake
Lift .100 .150 .200 .250 .300 .350 .400 .450 .500
Flow 76 116 161 192 195 204 214 223 224
Exhaust
Flow 66 102 140 166 178 185 188 189 190
I am sure I am forgetting more done to the motor
I have photos of the complete build. Photos upon request. I am open to trades for cars or cash offers. Don't Low Ball Me!!!
head milled .030
3 angle valve job
All Cometic gaskets
Injen Intake
The Block:
Bored over .25 MM
Moroso Oil Pan
ARP rod bolts
Fresh Hone
Fidanza Short Throw
Intake Exhast
1 angle
3 angle
Backcut angle
Exh seat pitted
Flow bench 2
Grinding stem tip 2
grinding backcut
Head resurface 1
head resurface 2
Int seat 45 ground
Intake seat 45 & 60
Intake
Exhaust
justhatched231
Oct 17, 2010 05:49 PM
