Main relay is clicking
Old Mar 5, 2010 | 10:36 AM
ek coupe's Avatar
Default Main relay is clicking
when i go to turn my car over my main relay or some where under my dash board is making a clicking and the car wont turn over. there any ideas on how to fix this problem or why this would be happening?
Old Mar 5, 2010 | 10:39 AM
mwaedow's Avatar
Default Re: Main relay is clicking
the main relay is supposed to click, once when you turn the key on, once when the fuel pump is done priming, and once when you start it. if it won't turn over, I'd check the battery or the starter.
Old Mar 5, 2010 | 11:37 AM
Former User's Avatar
Check whether you battery has a low charge. Charge or replace it and then go from there.
Old Mar 5, 2010 | 11:40 AM
420eg95's Avatar
First try tapping on the started itself, some times the seliond goes bad and a small tap of a wrench can make it work, if thats not it you have a dead battery
both can make a similar noise that comes from under the hood.
Old Mar 5, 2010 | 11:41 AM
ek coupe's Avatar
just replaced the battery
Old Mar 5, 2010 | 11:46 AM
When the key is turned to ON(III), the starter fails to crank the engine, right? If so, is the charge on the new battery now drained?
Old Mar 5, 2010 | 12:33 PM
EE_Chris's Avatar
Are the cables connected to the battery terminals TIGHTLY on?
Old Mar 5, 2010 | 12:47 PM
Schister66's Avatar
Man U FTW
Check the thermostat housing ground. I had a similar issue and it was caused by insufficient grounding near the starter. It may not be that ground, but the cause is most likely ground-related
Old Mar 5, 2010 | 02:01 PM
Yeah, I think you are talking about the G3 ground on the transmission. If it's disconnected, the starter won't work.
Old Mar 5, 2010 | 03:43 PM
Ej8_KiD's Avatar
check ur battery , mine used to do the same thing and the battery had low voltage
Old Mar 5, 2010 | 05:02 PM
ek coupe's Avatar
its not the battery i just replaced it
crxpwr1
18
Jun 30, 2007 09:03 AM
eth0r
Jul 8, 2005 05:19 PM
FindingEmo
Aug 5, 2004 06:46 AM
Jolf
Aug 14, 2003 03:44 AM
dumbchild
Sep 3, 2002 03:25 PM
