Cant find freeze plug or expansion plug on my ZC???
Old Mar 5, 2010 | 09:22 AM
triggerfast00's Avatar
TRIAL USER
Default Cant find freeze plug or expansion plug on my ZC???
DO THEY EXIST IM NEW TO ZC ENGINES AND I DONT KNW WHY MY RADIATOR FLUID LEAKS OUT FROM THE RIGHT REAR OF THE ENGINE.....THE ENGINE RUNS FINE OR IT DID UNTIL I THINK IT STARTED TO OVERHEAT AND BLOW OUT BLUE SMOKE SO I SHUT IT DOWN....NO ITS NOT BLOWN OR SEIZED.....JUST GETS HELLA HOT BECAUSE THE RADIATOR FLUID LEAKS OUT IF ANYONE HAS PICS OF WHERE THE FREEZE PLUGS ARE AT OR EXPANSION PLUGS ARE I WOULD APPRECIATE IT....OR IF THEY KNW WHY OR POSIBLE WHERE/WHY ITS LEAKING I CANT GET CLOSE ENUF BEHIND THE ENGINE FROM UNDERNEATH TO SEE WHERE IT ACTUALLY LEAKS FROM BUT IT LOOKS LIKE NEAR THE WATER PUMP/ WATER JAKCET AREA ON THE RIGHT REAR OF THE BLOCK....
please help im desperate to get my CRX back on the road....
Old Mar 5, 2010 | 09:29 AM
hatchet_honda's Avatar
Default Re: Cant find freeze plug or expansion plug on my ZC???
sounds like it may be your water pump. they have weep holes that fluid will leak from when the bearing goes bad
Old Mar 5, 2010 | 09:47 AM
Jockone's Avatar
X2 check waterpump.
Why are you shouting
Old Mar 7, 2010 | 05:00 PM
TRIAL USER
not shouting......lol caps was on didnt knw it.....and ya they have weep holes but they are usually big enuf to empty a radiator in less than five minutes after being filled....help me im desperate to fix my crx....and ps to both of you how do i check my water pump and wat do i look for im a retired accord fan dont knw much about smaller engines so im in the dark
Old Mar 7, 2010 | 05:31 PM
JLefevers's Avatar
kinda sounds like it is a heater hose, or somewhere around the thermostat housing if it is coming from the back side. If you have been around accords then you should be able to find it. Not much is different. G/L
Gathers
May 13, 2010 11:23 AM
alupso
23
Feb 2, 2009 05:27 PM
milo83
Mar 21, 2005 04:05 PM
DOHC_EF
Mar 19, 2005 10:18 AM
BIG RICH
Nov 7, 2003 05:51 AM
