Timing and Mileage when Changing fluids and major maintenance
Hi,
I am probably picking up this car: http://vancouver.en.craigslist.ca/rd...628609670.html
And when I get it, I need to figure out when to change the fluids.
I know oil should be changed every 3000-5000kms (3-4 months)
What about transmission, power steering, timing belt, water pump, PCV Valve, etc?
oil - 3k
5spd tranny fluid - 25k
power steering - 50k
timing belt - 100k
water pump - 100k
thermostat - 100k
coolant - 50k
acc belts and radiator hoses - 100k
clutch fluid - 100k (or 2-3 years, it's hygroscopic)
brake fluid - 100k (or 2-3 years, it's hygroscopic)
PCV valve - 100k
valve adjustment - 25k
remove & sand ground points (and battery terminals) - 100k
# are miles, not kms.
Get a Helms manual. Electronic copies can be found easily through Google.
timing belt - 100k
water pump - 100k
thermostat - 100k
coolant - 50k
PCV valve - 100k
glenmore
Acura TL, RL & ZDX
May 25, 2012 11:18 AM
Campee
Apr 2, 2003 09:32 AM
2001, 2005, 50k, civic, honda, hondatech, maintanence, maintenance, maintenence, major, mileage, s2000, schedule, significant, tl
