** CHIPPED AND SOCKETED P28 VTEC ECU'S **
We have the answers for your quality, fully reconditioned performance chipped ECU! All ECU's are chipped here in house for complete control over the quality and to ensure all ECU's operate properly before ever shipping out. Every ECU is first inspected upon arrival for any problems, then if everything looks great, it is thoroughly cleaned, then socketing using all of our tried and true components. After completion, we test each and every ECU to ensure that it operates properly before shipping. ECU casings are fully glass bead blasted for a "like-new" finish, ECU lids are charcoal grey powder coated for a durable finish, and shipped with a free factory calibration basemap of your choice for plug-n-play operation to get you up and running right away!
- Every ECU shipped with pre-installed ZIF socket for quick and easy chip changes
- FREE factory calibration basemap of your choice: P28, P30, PR4, P72, H22 on a re-burnable chip
- Add a custom basemap for $39 for features like launch control, adjust for larger injectors, and so much more
- Pre-Tested in on our state of the art ECU bench tester for trouble free operation
- VTEC and Non-VTEC ECU's available for almost any application possible
- made to order for complete quality control and customization possibilities
- order 24/7 online, or give us a call!
Browse our ECU's for the correct comibination for you on our online store:
chipped Non-VTEC ECU's
chipped P28 VTEC ECU's
Chipped P72 GSR ECU's
HA Motorsports
www.hamotorsports.com
http://www.facebook.com/pages/HA-Motorsports/305023231743
just wanted to say that im very happy with the ecu i had matt@HAmotorsports set up for my demon rtp set up! professionalism was great, costumer service was fantastic, and the quality of the install was next to none. no doubt have a dedicated costumer here. turn around time was great even with me changing plans in the middle of the install. thanks again matt! jim.
Looking for just an ECU chip kit instead of a complete chipped ECU? We have plenty in stock with all of the same high-quality components that we use on our chipped ECU's. We keep in stock USDM obd1 chip kits with Zif sockets, JDM ECU chip kits with ZIF sockets, VTEC conversion kits, custom basemap chips, and pretty much anything in between
http://www.hamotorsports.com/ecuchipping.html
Chipped P28 Ecu 's in stock, ready to ship with a free basemap!
http://www.hamotorsports.com/socketedp28.html
This is a chipped P28 ECU equivalent professionally socketed with our low profile ZIF socket for quick and easy chip changes. All Chipped ECU's are cleaned and tested prior to shipping to customer. Please select the free basemap of your choice, or order one of our Custom Basemaps for a one stop solution.
* Socketed and ready to use with Crome, Neptune, Uberdata, or other similar tuning software.
* Inludes pre-installed ZIF socket for quick and easy chip changes.
* Datalog header pre-installed for easy datalogging capability.
* Free basemap chip of your choice.
* OBD1 Chipped P28 ECU equivalent.
* Use with any D, B, H, or F series VTEC -or- Non-VTEC engine.
Choose any one of the following free basemaps:
* P28 92-95 Civic EX D16Z6
* P30 93-95 Del Sol VTEC B16A3
* P72 94-95 Integra GSR B18C1
* P73 JDM Integra Type-R B18C(5)
* P13 94-95 Prelude SI-VTEC H22A
* No core is required *
Chipped Non-VTEC ECU's in stock!
We stock plenty of our professionally socketed and chipped OBD1 Non-VTEC ECU's. These are P06 / PR4 / P75 equivalents socketed with our low profile ZIF socket for quick and easy chip changes. All Chipped ECU's are cleaned and tested prior to shipping to customer. You can select the free basemap of your choice, or order one of our Custom Basemaps for a one stop solution.
* Inludes pre-installed ZIF for quick and easy chip changes.
* OBD1 P06,PR4, P75 ECU Equivalent
* Use with any D, B, H, or F series Non-VTEC engine.
Hondata S300 prepped ECU's in stock and ready to ship!!!
http://www.hamotorsports.com/s300obd1ecu.html
Our S300 ECU's are socketed for use with Hondata S300 systems. The Hondata S300 can be either purchased with the ECU and installed for free, or you can purchase the ECU alone and install your own S300 system easily since the ECU is already prepped to accept the S300 unit. We completely socket the ECU with the Hondata S300 style pins, notch the ECU case for the USB cable, clean the ECU, and ship it out to you ready to go!
Believe it or not, we currently have many stock ECU's available as well. These are great if you have a stock engine swapped into your car or need to smog your car! These ECU's are all tested and cleaned before shipping. These are 100% stock, virgin, unmodified ECU's. See what we currently have available here: http://www.hamotorsports.com/stock-honda-ecus.html
Virgin P28 ECU's in stock and ready to ship!
http://www.hamotorsports.com/virginp28.html
if i have a 93 del sol with a d16z6 will this work for my car? and if i wanted to boost my car to 7-10 lbs what would i need to add? i have no idea how to tune a ecu for boost can you guys help with that?
Yes, a chipped P28 is ideal for your setup. We will need to know what injectors you will be running and engine/ turbo setup to program a basemap. The "basemap" is just that - we STRONGLY encourage you to get it tuned. The basemap is just a starting point and something to get you to a tuning shop.
