LCA Bolts type?
Alright I found the right size bolts and bought them but they are threaded the entire 80mm, so does that matter. I realized when I got home that it is not that way for the oem bolts but does it make that much of a difference? If it does I guess I can just return them and ask for the right ones.
ex. for ease...
that is similar to the one I have but mine is the right size and grade...
and that is what you really need.
So would mine cause problems?
ex. for ease...
I believe if you use a normal bolt without the longitudinal grooves like stock, it may be more prone to seizing up inside the bushing, even more so than the stock bolts. I could be wrong, though.
I, too, bought bolts similar to the 2nd pic when I first put on my Koni shocks, just in case. Luckily, I never had to use them.
I'm still using the original OEM bolts (never had any of them break on me *knock on wood* ). The ones I got just in case were like the ones in your 2nd pic.
I know one thing, the pointed end of the OEM bolts sure makes it easier to pound the bolt through the holes to get everything lined up.
