need help...d15b - d16z6
Old Mar 4, 2010 | 01:52 PM
adobo310's Avatar
Default need help...d15b - d16z6
what do i need for this to work in my 89 ef9... first time doing this swap any input would be great... this is what i got 1989 ef9 with a d15b non-vtec and i have a 1994 civic with a d16z6... so what do i need? any help will help thanks..
Old Mar 4, 2010 | 02:54 PM
lunalink's Avatar
Default Re: need help...d15b - d16z6
need for what? to swap in the z6 into your ED ( ef is RHD ) be more specific
Old Mar 4, 2010 | 05:43 PM
black0hatch's Avatar
you need the complete swap ecu and everything. then you gota rewire you car from dpfi to mpfi then you got get a jumper to convert it to obd1. everything will bolt in the main thing you need to worry about is the wireing. oh and use your stock cable tranny or convert it to hydro if you want to use the 94 tranny.
Old Mar 5, 2010 | 03:30 AM
Sikocivic's Avatar
You will also need the motor mount bracket on the drivers side of the motor from the D15. You may have to notch the upper timing belt cover on the Z6 to get it to fit. I had to cut about 1"X2'' piece out of mine to get it to fit.
Check the FAQ, there is all the info you need to do this swap already there. I used those wright ups to do mine and had no problems.
Old Mar 7, 2010 | 11:08 PM
BeatEG's Avatar
Hey this is not my thread but im jacking it because i cant start net threads yet. I have a more specific question and any help would be greatly appreciated.
I am taking my complete d16z6 out of my 93 del sol and putting it in my 92 four door eg that was stock with a a d15b7
as far as the wiring i know i have to run the 2 wires (wires 1 and 2) in the pic to ecu for the v-tec . I know where these go .
Its wires 3,4,5 that i cant find any info on.. Where do they go? do i need them? and where should i hook them up?
let me know if you need more info thanks..
this is the chassis harness in the four door
this is the chassis harness in the del sol
this is the engine side of the harness on the 1.6
Old Mar 8, 2010 | 11:36 AM
BeatEG's Avatar
bump ... anyone?
Old Mar 9, 2010 | 04:40 AM
Sikocivic's Avatar
Originally Posted by BeatEG
bump ... anyone?
Your asking that question in the wrong forum. This is 88-91 Civic/CRX. Go to the Honda Civic/Del Sol (1992 - 2000) forum and ask them.
Old Mar 9, 2010 | 08:14 AM
BeatEG's Avatar
oops sorry..... thanks
zeroairskter
Dec 28, 2010 10:57 AM
1low88ef
Jun 3, 2009 07:44 AM
crxtra
16
Jun 29, 2006 09:46 AM
