93 accord with prelude si wheels
Well i have a set of 92 prelude si wheels. I want to put these on my cb7 however when i did it rubbed like crazy. Is this a tire issue or does running these require some spacers.
Well, you don't say where it rubbed, what rubbed, if you have stock suspension, how low you are, if you have a camber kit, and what tires are currently on the wheels.
Until you answer those it's like shooting in the dark.
Well it was dark when I put them on, and didnt have time to check. The accord has stock suspension. The tires on the prelude wheels are 205/55 15.
The only way it could be rubbing with stock suspension is if they aren't Prelude Si wheels. I think the most spacer you'd want to put on would be 5mm spacers. Something tells me there's more to it than what info you are providing. It's very unlikely they would rub at all without some negative camber.
It definitely shouldn't be rubbing on the fenders from the tire, you *may* be rubbing on the inner fender well though when the wheel is cocked all the way to one direction. I had 205/50/15 on my ITR's and I was slammed without any rubbing issues
TypeSH
May 3, 2002 02:05 PM
