ZC head on si block
well now.....I wouldnt jump to conclusions......I know im prob. wrong...but I could swear to god that I read some guys did this with an integra head onto a older si block......
Doubt it would work but who knows with these damn honda's
funny thing tho, I compared the head gasket from my motor (the D15A1, or EW in the 1G CRX Si) to a D16A1 head, and it will work. Everything lines up. Onlything is, timing belt/piston issues are unknown. Don't get too excited, my engine is completely different from other D-series blocks.
What I do know is a 88 Integra head won't work on an 88-91 D16a6 block. It will bolt up but everything valve train wise and coolant/oil passages is slightly misaligned. It would probably run but would go through a ton of headgaskets. I'm sure w/ some machinework it could be done but for the money you could just buy a ZC w/ more power. As far as a 1g/3g Si motor don't know but doubt it would work.
It has been done before. There is some machine work that is required in order for it to work. Unfortunately the cost/benefit ratio is no good. You're way better off getting either a Y8 head, or an entire ZC motor - these will be less of a hassle, might end up costing less, and will produce more performance.
It's a good idea tho.....
DOHC head on 88-newer D-series = prolly really hard to do and prolly not worth the work. Mini-me is better.
DOHC head on an EW (1g rex/3g civic) = likely possible without too much work, value unknown.
david_efguy374
Oct 28, 2008 05:25 AM
potential
Aug 2, 2006 09:58 AM
